Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Power comes on the shuts off after 3-5 seconds
Slx2 powers on then shuts right off
I'd give you the same suggestion. Send it to the company for testing.
Jul 04, 2014 | Shure SLX2/Beta87A Professional Microphone
Having problem with lennox furnace Model ML193DF090P48C-02.Furnace has been working but now and getting worse furnace will kick on 20 seconds or so but nothing.Igniter does not come on.When it finally
Usually when your flame sensor gets dirty, the igniter and burner come on for approx.15 seconds, then shuts down. After 3 tries it will lock the furnace out. You have to shut the power off to the furnace then turn it back on to reset it. You need to turn all the power off to the furnace and remove the flame sensor, clean it with some very fine steel wool and put it back in. Be careful not to handle the Sensor (metal) part with your fingers. Turn the power on and set your thermostat so that it will call for Heat. That should fix, it if not you may need a new flame sensor.
Mar 16, 2014 | Heating & Cooling
Sansui hdlcd185w shuts down after about 3 seconds
My sansui LCD tv is getting on after plug in to power supply but it is not getting on after switching on the remote/tv ,display is not coming pls help me
Sep 01, 2012 | Sansui 19" Class LCD 720p 60hz Hdtv,...
Power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Apr 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
