Question about Brother IntelliFAX-2840 Laser Fax Machine
Brother fax 2840 squeaking when printing
After changing out the toner that came with our new machine with a brother toner replacement, the machine is squeaking when it is printing a fax.
  • 42 Answers
SOURCE: poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Posted on Mar 17, 2008
  • 320 Answers
SOURCE: brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Posted on Jan 19, 2009
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
  • 215 Answers
SOURCE: TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Posted on Feb 06, 2009
greg_margo
  • 1959 Answers
SOURCE: Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
  • Did you gently rock the toner cartridge from side to side to evenly distribute the toner?
  • Did the cartridge "click" into place?(did lock lever pop up when it was inserted)
  • Did you replace the protective cover securely?
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
Posted on May 06, 2009
How do I replace the DR420 drum unit
Open the front door, remove the cartridge, take apart the Toner and put it on the new drum and put it back. make sure you reset the counter. ALL info are in the New Drum box
Sep 24, 2014 | Brother IntelliFAX-2840 Laser Fax Machine
Print quality on Brother Intellifax 2840 fax/printer has changed from black to gray. I've tried different toner cartridges, but it doesn't help.
The online fax service allows you to choose the quality or your outbound faxes: black and white thresholding (with improved readability) or grey and colors dithering (to render grey zones of pictures and logos).
Aug 12, 2013 | Office Equipment & Supplies
Change toner error brother 2820 mach has new brother toner ctg
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4100 squeaks when printing faxes
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
How can I change the print quality of faxes received on my Brother IntelliFAX-1270e machine. Paula
You normally can't control the print quality of what you receive. You might try a new toner cartridge.
Aug 14, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX-2840 Laser Fax Machine Logo
65 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
