Question about AUDIO-TECHNICA U.S. INC. CONDENSER USB MICROPHN - ATR2500-USB -
Windows 7 doesnt install atr microphone correctly
I plugged in my usb mic into my computer, and it always fails to install
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Gotta go to Windows Tech support
Posted on Apr 22, 2014
Microphone does not work correctly
do have a spare mic to try
skype has its microphone test function ..
my mic is usb
in computer settings or systems
see if the device is working there
(windows 10 ) try this
look for connected usb devices
see if the mic is showing on the list
if not then the mic its plug it self or the computer socket is the problem
May 20, 2016 | Computers & Internet
Why Behringer C1U not recognized ?
Did you install the mic's drivers before plugging the mic in? Have you tried it on 32bit operating systems other than Win 7? I don't think it will be an audio driver problem ie: asio4all. But because the OS doesn't recognise the driver automatically it might indicate where the problem lies. I am not familiar with this particular mic ( I use AKG cs1000s with Zoom R16 audio interface ) but I know there can be issues with some 64 bit systems and certain audio hardware. Nothing in the Behringer forums?
Aug 21, 2014 | Behringer C1U Microphone
My windows laptop does not detect the mic when i plug it in. it used to, and i know that the mic works
If using windows 7 go to sounds then properties then go to microphone than make sure enable after that test levels
Oct 14, 2013 | Audio Technica Audio-Technica ATR-20...
Connection
if it plugs into the line in or mic in using the 3.5 mm plug then no, the mic won't need a driver. Your playback and recording devices on your computer DO need drivers. Sounds like a computer config issue to me. Could be a few different things
MTP USB device failed to install on Windows 7
Did you instal the software that came with your camera?
You also can download the new View NX from Nikon for free. Always first install the software, before connecting any device on your computer. Special what it is a device like a camera.
The computer can interpret a camera on an USB for: Now I nave to charge the battery. Or when you start the program to transfer pictures, now I have to download pictures, or some camera's like your D200, also cam be controlled remotely over the USB, if the correct software for that is installed.
The software windows needs to install has to be on the computer first.
May 15, 2013 | Nikon D200 Digital Camera
I have a dynex dest mic and it is not working
See if your computer is setup correctly to use it. go to my computer ---control panel ---sound.
Also check the volume control and make sure the mic is'nt muted. If this is a USB mic drivers
may need to be installed for it. Check the device manager and see if there is any problems
under my computer ---- view system information ---- Hardware -- device manager. If this is an
analog mic make sure its plugged into the soundcard correctly. If using front plugs on the computer
make sure the soundcard is set to use front mic.
May 19, 2011 | Dynex Voice-Certified PC Desktop...
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
AUDIO-TECHNICA U.S. INC. CONDENSER USB MICROPHN - ATR2500-USB - Logo
35 people viewed this question
Top AUDIO-TECHNICA U.S. INC. Office Equipment & Supplies Experts
jasbo
jasbo
Are you an AUDIO-TECHNICA U.S. INC. Office Equipment and Supply Expert? Answer questions, earn points and help others
