Question about Vizio E421VA 42 in. LCD TV
Volume goes up, picture freezes, tv reboots
After about 3 hrs of operation, volume goes us, 30 sec later, picture freezes, 10 sec later the tv reboots, is it a power supply problem?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Posted on Apr 22, 2014
4 Suggested Answers
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
  • 608 Answers
SOURCE: After power outage about 30 secs my VT420M comes
You my have a bad capacitor. I had a similar problem with my 42 in Phillips. I did some research and found that a lot of electronic devices made only a few years ago were having all sorts of problems because of capacitors. They fail after 2-4 years due to a lack of preservative. If its still under warranty no big deal. If you are not, you might look into getting a new Power Supply Board.
If you are willing to open your TV up and take a look at the capacitors on the PSB(the board that the power cord comes into) you may find your problem. Blown capacitors look bulged or leak. sometimes they show no sign of a problem but if there are any visible signs you know for sure.
They are replaceable but it takes a few soldering skills.
Posted on Dec 08, 2010
sr6248
  • 66 Answers
SOURCE: Visio TV freezing and then rebooting
If you can get into the setup program, try doing a factory reset to get back to the default setup settings. This may cause you to lose apps that you have added to the set, however, but that's better than having to buy a whole new set. You also may want to see if there are any updates for the set from Visio if you don't have it set up to download and install them automatically already.
Posted on Feb 21, 2014
Vizio sv422xvt lcd tv , freezes shuts off and reboots at random, need fix advice, total reset didn't work
Sounds like you might need to replace the main board on the unit. Make certain you get the right one or it will not work. E-Bay might have one.
Oct 03, 2017 | Vizio SV422XVT 42 in. LCD HDTV
How do i fix my tv
I had the exact same problem. Thought I could fix it by replacing the thermal fuse . . . no luck there. Problem continued. After tons ( I do mean tons) of research, I found the problem to be a temperature sensor. Makes total sense ! ! ! The tv is trying to come on, but the temperature sensor is bad, telling the tv that it is too hot to operate, so it turns itself off - only to try & come back on 30 secs or so later. Hard to fix unless you know your way around tv circuits. Took me bout 3 hrs total.
Nov 08, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv turns on about 30 sec later screen goes black sound stays on for about 5-10 sec then just goes off then all 3 lights blink looks like a frowning face i have replaced my bulb about1 year ago is there any...
Bad lamp again. The lamp life is not dependent on install date but more the amount of use. Ebay for the lamps, a lot of the time you can get them 50% off for refurbs.
Jul 28, 2011 | Samsung HL-S4266W 42" HDTV
My tv comes on runs for 30 sec. then loses sound and picture for 30 sec. and the standby light flashes green for 30 sec. then the picture and sound comes on . then about 30.sec. later it does the whole...
It is symptom of weak lamp that has been reached to an end of its working hours life but not dead/ broke yet.
If lamp has not been replaced in last 2-3 years then please replace lamp in tv to get solve this problem.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 11, 2011 | Sony KDF-E50A10 LCD TV
I bought a 52" plasma
you can try unplugging it for 10 secs, then plugged back in. Press and hold the menu button and minus volume button on the actual tv. While still holding those two buttons, press the power button. Continued to hold the menu and minus volume button for additional 3 secs. The tv should turn on in about 30 secs. If that does not work call customer care.
Jan 12, 2011 | Televison & Video
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Sep 04, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Vizio E421VA 42 in. LCD TV Logo
184 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
