Question about Vizio VO47L 47 in. LCD TV
5 year old Vizio WW46L faint lines on right side of the screen
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
If you saved the manuel or original paperwork it will tell you how to trouble shoot, if not pull up your model online with the instructions on how to troubleshoot
Posted on Apr 22, 2014
  • 142 Answers
SOURCE: Vizio L37 37" LCD screen screen is cracked.
I agree your screen is cracked. It's smooth to the touch because you're not actually touching the LCD section of the screen, just the protective coating. The advantage of owning an LCD TV over plasma... you can replace the screen either by going to the manufacturer or some place like e-bay. It's not a difficult thing to do if you take your time and pay attention to the details.
Good Luck
Posted on Apr 09, 2008
aminic
  • 61 Answers
SOURCE: Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Posted on Sep 20, 2008
  • 1779 Answers
SOURCE: red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Posted on Apr 21, 2009
eagle338
  • 4889 Answers
SOURCE: I have a 2 year
Can you pleas upload an image to imageshack.us and get me the link so that I can see what it looks like?
Posted on Oct 31, 2010
  • 718 Answers
SOURCE: i have an vizio 32"
This looks like the cables connected to the T-CON board may have worked loose.
The T-CON or timing controller, is what sends the video signal to the LCD (sometimes called LCD controller). The cable connectors on this board have very small contacts. Sometime some of them can become loose because of heat, contamination, shaking etc.
IF you know how to work on electronics or have a friend with knowledge/skill you can repair it.
DO THIS ONLY IF YOU KNOW HOW TO WORK ON ELECTRONICS.
> Disconnect all cables/cords on the back of the set.
>Lay the set face down on cloth covered flat surface.
>Remove the back of the set.
>Remove the metal shield covering the T-CON board. This board generally located in the center near the top.
>You can wiggle the T-CON cables around (for better contacts) to try and get the streaks to go away.
> Set tv upright so it is stable.
> Reconnect the signal source and power cord. DO NOT TOUCH ANYTHING ON BACK OF SET!
IT IS ELECTRIC !
> Use the remote to turn on the set. IF the streaks are gone, then turn set off
and UNPLUG THE SET and remove the input signal cable.
> Replace the shield over the T-CON board.
> Replace the back cover.
Resume operation.
IF moving the cable does not improve the signal you can disconnect/reconnect the cables and see what the picture looks like. Be careful not to damage the connectors. They may have clip that must be released first before removing.
IF disconnect/reconnect the cables does not work you can purchase another T-CON board and install it. The boards are relatively inexpensive.
I think the board will look something like this;
!bw!llnwcwk~$(kgrhqn,!icev1+0f2hlbmg89w0)sq~~_1.jpg?set_id=880000500f
Posted on Feb 16, 2011
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link http://electronicshelponline.blogspot.com/ to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Jan 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vertical lines in my laptop screen
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Vizio VO47L 47 in. LCD TV Logo
57 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
