Question about Canon CLC-700 Copier
Copier won't stay on. Canon clc700
Clicks off as soon as you remove your hand from the button switch. If you hold the switch, it seems to be trying to start up, but as soon as you release the button, the machine turns off again.
    Problem Solver:
  • 7 Answers
Most likely the either the scanning lamp or the fuser lamp circuit has on 'open' in it. Check the fuser lamps to make sure they are not burned out and make sure the thermal fuse it good.
Posted on Jun 21, 2009
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Jets won't stay running
Sound like a bad switch. The contacts are likely corroded or broken.
Aug 23, 2017 | Jacuzzi NOVA 5 WHIRLPOOL WITH INTEGRAL...
Is it not possible for a Canon "expert" to give a single solution answer to the error "6C10" that so many of us seem to get. The rest of the printer functions are fine. It's not...
Hello pattrickdavi
Try this solution :
Start with printer off
  1. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  2. While holding the Power button, release the Resume Button.
  3. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  4. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  5. Turn off the printer and turn on again This solution came from http://www.fixya.com/support/t4097826-aborber_full_error_message#sf and seems to work with several issues . Good luck ! fanaudi .
May 19, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Canon np6030
Most likely, you have a problem with the scanning lamp.... When you turn the copier on, will it turn right off? If so, try to hold the power switch "ON". The Display pannel will flash a Error Code... It may be a E0200 or E0220 or E000. Get the Error Code and get back to us... I think you have a heat or scanning lamp is shorting out... Good Luck
Mar 28, 2009 | Canon NP 6035 Copier
Cannon clc700 error E073
there is a problem with the transfer drawer
Dec 27, 2008 | Canon CLC-700 Copier
Canon MP150
Try holding the Reset button for 5 seconds or more; this may have to be repeated several times.
Mar 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon CLC-700 Copier Logo
67 people viewed this question
old marine
old marine
