Question about Microwave Ovens
Soup problems I made home made bean soup using dried navy beans that I soaked overnight, however after 2 hours of cooking (simmering) they are still tough. Any suggestions?
  • Patricia Pelka
    Patricia Pelka Apr 22, 2014
    I goofed. I should never have ask this question on this appliance site. Sorry!
5 Suggested Answers
  • 79 Answers
SOURCE: when using on small amounts of food would burn (spark & flame)
Sparks in microwaves are caused by metal things in there. What kind of plate - any metal or gold leaf decoration on it?
Try a microwave safe dish.
Make sure you do not use metal items in microwaves.
I do not know the model number of your nuker, is it a new one or old? How long have you had it, and has it always done this?
Posted on Apr 26, 2009
  • 8909 Answers
SOURCE: basic questions on just re-heating
I should think that would work alright. You can always adjust the times as you get used to the different power settings etc.
Posted on Feb 07, 2011
heatman101
  • 43501 Answers
SOURCE: I need to know how
Get it to high pressure for 2-3 min.
Click here for a great chart with times for many things...
heatman101
Posted on Jul 16, 2011
ercupa190
  • 12223 Answers
SOURCE: lights and power work but not heating food
see this causes and fix it. God bless you
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest.jpg mwswitchtest2.jpg If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode. Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Posted on Oct 02, 2012
How do I remove salt from a soup after it is cooked?
you put peeled potato in it for a while, than take it off, the potato will absorb all the salt.
Jan 24, 2015 | Microwave Ovens
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
I need to know how long to processing green beans when using the pressure canner.
heatman101
Jul 16, 2011 | Microwave Ovens
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
Have a Proctor Silex small crock pot, no manual. Setting are Off, 1, 2 and "AutoShift". There is no timer. How can it be set to (1) be sure to cook the food long enough and (2) stay on / keep...
You can find a Use and Care Guide for your product at the following website. You will need to locate the model number of your crock point. Select Slow_Cookers in the product field; Select your model number and click on Submit.
A pdf file of your Use and care Guide will be provided; note they are scanned files and some are of poor quality.
Model 36400 has a similar control to your model. The Guide provides a table of the time to cook at settings 1 (low), 2 (high) and Auto Shift. Auto Shift starts at the high setting and then decreases to the low setting. The time to cook at Auto shift is in between the time taken at the low and high settings. The low and Auto Shift settings are designed for long cook times at a simmer. On the high setting some foods like soups will come to a boil and may need stirring during cooking.
The crock point has no auto turn off and will keep foods at a simmer when on the low or Auto Shift settings. With some practice you will learn how much time this will take for various foods.
The sure way is to use a tip sensitive digital instant-read thermometer to check the final temperature of the food. Check according the guidance provided by the Partnerships Food Safety Education:
http://fightbac.org/safe-food-handling/cook/127-cook-heat-it-up-chart?format=pdf
Feb 06, 2011 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
When using on small amounts of food would burn (spark & flame)
Apr 26, 2009 | GE Microwave Ovens
A rattling noise
You have a problem with the microwave stirrer motor. Cost of part is near $90 and will require 2+ hours to get to, exchange and close back up.
Either get a new microwave of put up with the noise (which I did for 6+ years).
Nov 18, 2008 | Whirlpool GH8155XM Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
