Question about Altec Lansing ADA425 3-piece 30-watt Speaker Set Computer Speakers
Creative 9pin connector diagram - Altec Lansing ADA425 3-piece 30-watt Speaker Set Computer Speakers
  • Altec Lansing Master
  • 3,320 Answers
FOR WHAT?
Posted on Apr 22, 2014
2 Suggested Answers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Altec lansing mx5021 pls. give the 9pin wiring diagramthe the color code 9pin going to mainboard.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 11, 2015 | Altec Lansing MX5021 System
I have @ panasonic plasma display model TH=50PHD7UY serial YH5120189 and my question is how can I connect cable tv in to because does not have the connector on back?
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
Jul 21, 2011 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
I need to plug a 9-pin connector to a usb inside the computer but don't have a 9pin inside the computer. I do have an internal usb port so is there a converter?
Sounds like you're looking for something like this:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=1116
Jun 16, 2009 | Belkin 2 Port KVM with Integrated Cables -...
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Dsub connector
i believe best buy has the adapter, i found one there myself for my pioneer home movie sys.
Dec 12, 2007 | Universal Remote Control MX-800 LCD Remote...
104 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
