Question about Cub Cadet Garden
When I turn on the pto nothing happens
While I was Mowing the pto stopped working
  • Cub Cadet Master
  • 2,392 Answers
Check the shear pin. Could have snapped and needs replacing.
Posted on Apr 23, 2014
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 51 Answers
SOURCE: the mower turns on fine but when i engage the pto
could have bad pyo switch or pto clutch.make sure every thing turns freely,blades and pullys then unplug clutch and try to enguage if does not blow fuse check clutch with meter. put meter on ohms probe one terminal and other on ground via clutch housing should not have continuety check other terminal to ground.voltage goes in one term and out the other like litebulb if potting (insulator) in clutch is melted wire inside will short on housing.hope this helps
Posted on Aug 15, 2010
  • 4 Answers
SOURCE: electric pto will not engage
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Posted on May 01, 2011
  • 695 Answers
SOURCE: was mowing-blades just quit turning-pto
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
Posted on Jul 05, 2011
  • 2239 Answers
SOURCE: PTO WILL NOT CUT ON
I would check that you have a 12 volt supply down at the clutch when the pto switch is pulled out, if not you need to investigate the wireing and or micro switches,
Posted on Mar 13, 2012
PTO stopped working. What can cause this to happen?
bad safty switch or bad switch or pto burned out pto cost 200.00 switch engagement 15.00 or bad safty switch 15.00 pto dont go out that often not unless your mowing heavy grass
Aug 29, 2014 | Garden
Why would blades just stop when mowing with ex mark lazer Z (model lz25kc604) I had beeing mowing for about 6 hours. Then it just stopped
It sound like the PTO clutch has died.
Test your PTO clutch. It should have a resistance of 1.7 to 2.5 ohms.
Jul 27, 2014 | Garden
While mowing along my blades stopped turning. i shut the pto off and tried again. i noticed the battery light comes on when i turn the pto on. i let the machine cool off and tried again. the pto turns on...
Did it work right after you changed battery? It sounds like your regulator/rectifier isn't recharging your battery. When the battery isn't charging properly the pto wont work for long. If you have a multimeter, hook it up to battery while unit is running and check voltage on battery. When idle is high you should see more charge and vice versa. Please exercise caution when doing this. Hope this helps.
Aug 01, 2013 | Garden
I have a Toro Zero Turn 50" mower with a Kohler 16HP engine. My PTO switch melted
pull the wires of of the pto in case it is shorted check charge at battery tomake sure wires havnt rubbed through
Feb 10, 2013 | Toro Garden
Electric pto will not engage the mowing deck. stopped working while mowing.
Aug 01, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Engine stopped while mowing...tried to restart...nothing.
I am having the same problem. The PTO in engaged and won't relase. The engine won't turn with PTO engaged, you need to disengage the blades to restart.
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I think i may need to replace the pto clutch on my stx38...is it difficult to do? Also, how can i best determine whether it is the pto clutch or perhaps the switch that activates the clutch. currently,...
Depending on the age of the mower, it sounds like a wire has wiggled lose, or the switch itself has gone bad. I would check the wiring to the switch and to the pto clutch and ensure that all wires are secure, free of corrosion. If this still doesn't fix the issue, install new switch. This appears to be entirely and electrical issue, and is a cheaper troubleshooting method before tearing down the pto engagement system.
Let me know!
Chip
May 31, 2010 | Garden
I have a Cub Cadet 1250. The PTO suddenly stopped
Look at www.cubcadet.com. There under parts you should find an IPL for your mower. You will need the model and serial number from under the seat to get the information. Look under the electrical for PTO.
HTH
Good Day.
Oct 29, 2009 | Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
