Question about Dell Computers & Internet
Dell Power Supply Model #TFX0250D5W
Computer will not turn on, how do I troubleshoot power supply?
    Sergeant:
  • 240 Answers
First, check that your power cable is not faulty; believe it or not, it is a common problem.
Second, check that your power switch has not shorted out; that is another common problem.
Third, the only way to check your PS is to swap it out with another. If you don't have one, you can also order a power supply tester (which is what I have). Try Newegg.com and type "power supply tester" in their search box. Also check the user reviews for dependability.
Posted on Apr 23, 2014
Testimonial: "Yes, it was very helpful. It helps to know that you need the right tool to troubleshoot the problem. Thanks for your helpful advice."
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
  • 233 Answers
SOURCE: Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Posted on Jun 11, 2009
  • 489 Answers
SOURCE: My Dell Precision 380's power light is orange
Check all of the electrical connections to all devices in the machine, especially the motherboard. Many times this is a result of a poor connection being jarred loose during a move.
Posted on Jul 07, 2009
Creative Con
  • 55 Answers
SOURCE: need pin assignment for model: m2n61-ax
If this is a Dell Inspirion 531 here is the owner maual with all the components
http://support.dell.com/support/edocs/systems/inspd531/en/OM/45605A00MR.pdf
Posted on Oct 10, 2009
I want to download dell rev a00 motherboard driver
go to dell web site then to support then type in board some do have autodect ok
Mar 19, 2014 | Bestec Dell TFX0250D5W Rev X4,Rev.:A00...
Wiring bestec atx 1523d to bestec tfx0250d5w revx4
Are you replacing one with the other or trying to wire them together? If the latter, why are you doing so? If you need more power, you'll want to buy a bigger power supply. I suppose you could wire it to use two, but you'd have to find a way to trigger the second power supply to come one or do it manually. I wouldn't try it unless it was an absolute last resort with no other options, though.
Jan 01, 2014 | Dell Computers & Internet
No Pwer
The Power Supply is bad dwadley.
Weak voltage power rail.
Primer;
1) IF all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
The Dell Inspiron 530s series of desktop computers, come with an Intel processor.
Options are either a model of Core2 Duo, Pentium Dual-Core, or Celeron.
http://support.dell.com/support/edocs/systems/insp530s/EN/OM/HTML/appendix.htm
Click on Specifications.
Replacing the Power Supply,
http://support.dell.com/support/edocs/systems/insp530s/EN/OM/HTML/parts.htm#wp1578680
In the middle column at the bottom, click on Power Supply.
The computer is an SFF design. Small Form Factor.
http://www.dell.com/us/dfh/p/inspiron-530s/pd
Because of the space saving design, the Power Supply is an SFF design also.
Makes it special.
Just one example, not a recommendation. You search for the best price and quality,
http://www.discountelectronics.com/index.php?l=product_detail&p=2782
Click on the Power Supply image.
(Whew! That get's great big! NOT!)
An average ATX power supply's dimensions (Used in most mid-size, and full size desktop computers), is approximately;
6 Inches Wide, 5-1/2 Inches Long, and 3-1/2 Inches Tall.
The SFF power supply dimensions in your desktop computer, is around
4-1/2 Inches Wide, 3-1/2 Inches Tall, and 5-1/2 Inches Long.
The dimensions are what makes it special.
Another view of the Power Supply,
http://www.ebay.com/itm/Bestec-Power-Supply-TFX0250D5W-Dell-Inspiron-Replace-537S-530S-531s-540s-/270938215966?pt=PCA_UPS&hash=item3f152d161e
1) Computer on a table, computer unplugged from power, (AT the surge protector side. NEVER unplug at the Power Supply side), computer case open.
2) Follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the hardware components inside a computer.
Relieve your body of Static BEFORE working on the computer.
Again, computer on a table.
A bed, couch, or directly on a carpeted floor, are HIGH areas of Static.
If your table is on a carpeted floor, refrain from swinging your feet across the carpet.
Computer unplugged from power, computer case open, TOUCH the metal frame of the open computer case, (Unpainted surface), to relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Opening the computer case;
http://support.dell.com/support/edocs/systems/insp530s/EN/OM/HTML/parts.htm#wp1508953
4) You will have to disconnect all power cables, leading from the Power Supply. (Upper rear of computer case)
Make notes, and drawings as to where each cable plugs into.
If you have problems when reconnecting the power cables, Relax.
Just post in a Comment, and I will guide you step by step.
The plastic Front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) from the Front Panel go to; is the Front Panel header.
DEFINITELY make notes, and drawings, as to what Front Panel cables, plug to what contact pins, BEFORE touching anything inside the computer.
If you accidentally knock a cable off a contact pin, (Or more than one),
I Do NOT have the pinout to give you.
(The Front Panel cables may all go to one connector, that fits over the Front Panel header contact pins. I do not know.
Haven't worked on one yet, and have not owned one.
Each Front Panel header, and Front Panel cable connections, are specific to that computer.
The rest of the technology used inside the computer, is just standard desktop computer technology. )
For additional questions please post in a Comment.
(And/Or to have me explain further on anything I have stated )
Regards,
joecoolvette
Mar 19, 2012 | Dell Inspiron 530s Desktop Computer
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
Feb 15, 2011 | Dell Inspiron 1721 Notebook
TFX0250D5W Rev x4 Cooling fan getting noisy. (Dell Inspiron 530s)
Check it for dust / dirt. Clean it or replace it.
Good luck,
Jeff Mc.
Jan 15, 2011 | Bestec (ATX100-5) (ATX1005B) Power Supply
My Dell Dimension 5100C will not come out of sleep mode. Everytime i press the power button, the light blinks orange and keeps blinking ,no noise from the inside or anything. It Just stays in hibernate...
the continuously blinking yellow litght indicates that the power supply gets juice from the line but cannot distribute powe to the components. the first thing to do is to check and see if the power supply is working. dell power supplys have a test button, if you turn the computer around and hold the button on the power supply down for a few seconds the light should turn green, if it dosen't then you need a new power supply. if the power supply is ok, turn the computer on and have a look at the diagnostic lights (on the back, labeled 123 and 4) if you call the dell support line and tell them your model number (or give them the service tag) and which of those lights are on they will be able to tell you what the problem is. if you are still in warranty they will fix you, if not they will direct you to someone who can.
1-866-243-9297
Aug 20, 2009 | Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Computers & Internet Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
