Question about Dryers
Dryer will not turn on
We have a Samsung front load electric dv220aew. It will not turn on. We tried cleaning out the filter and hose. It will sometimes turn on after unplugging it, but turns off when I try to start it. An electrician came today and the outlet is good along with the cord. He tried Samsung tech support but they would not help him. It is only 3.5 years old. Any ideas? Thanks!
    Problem Solver:
  • 12 Answers
Sounds like you have a blown fuse. Best way to deter min would be to unplug the dryer and get a look inside. There are always 1 or 2 fuses on or near the control board. Remove the fuse, if you have fuses that will fit test them out. Always use a fuse with the same exact limitations. If you don't have any spare fuses take it to your local hardware store. they can test and replace the fuse. When these internal fuses go out it is usually an indication of a bigger problem and replacing the fuses only fixes it temporarily.
The best would be to get a more reliable electrician to look your machine over.
If an electrician has to phone tech support and still cant fix your problem he better not be charging you.
Posted on Apr 24, 2014
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
maddogsteve1
  • 18 Answers
SOURCE: Model 84152 beeps and won't start
probably the thermistor is bad. located on the blower housing in front of the motor nest to the thermostat. if you tilt the console back(remove the screws at either side, either visible or under snap off console ends) there is a tech sheet wiring diagram to trouble shoot the circut. unplug it first...
Posted on May 24, 2009
  • 10865 Answers
SOURCE: blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Posted on Jun 22, 2009
  • 8404 Answers
SOURCE: LG DLE5977 electric dryer, 3 years old. On power
Your belt is likely broken. I am presuming you DO NOT have a setting on your machine that allows the drum to not turn or if yours does have such a setting you have not selected it!!!
I am not intimately familiar with your particular LG model even though FixYa.com rates me a LG expert.
Dryer tops are generally held in place with spring clips. Pop the top being careful to not mar the finish. Look for the belt (about 3/8 inch or so wide). The belt will be near the middle of the drum. Try to pick it up. If it is broken, you will be able to remove it. If it has slack in it but you can't remove it, it is probably off the motor pulley. Put it around the pulley through the belt tensioner.
Remove the front - use care you don't damage any wires.
The drum will fall free at this point. Take pictures with your cell phone to aid in reassembly.
You can get replacement belts from a FixYa.com advertiser, your local appliance parts place or visit www.repairclinic.com
Thanks for using FixYa.com
Please vote
positive comments appreciated
thanks
a
Posted on Dec 06, 2009
  • 1531 Answers
SOURCE: frigidaire front load dryer won't turn on at all
check the main power and terminal block make sure there is power and no problems with the terminal block.
also a bad thermal fuse can cause a problem with the power check the thermal fuse and make sure they have continuity.the last thing to look at is the main control board these can cost up 150.00 dollars depending on where you get it.Bottm line yes i would say it is worth fixing
Posted on Jul 27, 2010
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Samsung WF328AA Front Load Washer
My dryer is running, but not producing heat.
IT COULD BE 1 OF 3 THINGS RIGHT OFF, 1) THE HEATING ELEMENT IS BAD, 2) the fuseable link is bad. 3) there may be a cracked porcilan insalater,whitch in turn can result in the first two problems, i would say the 1st is your problem, also not cleaning the dryer filter after each load and washing it regulary wil cause exsesive heat build up and cause a fire potential, also try not to use dryer sheets this causes wax buildup on the filters. the best way is to use a liquid fabric softner in the wash. and check the dryer exhaust hose and the exhaust hose outlet outside for any kind of blockage i.e. lint,or somthing setting in front of it ,good luck,
Jul 31, 2011 | Roper REX4634KQ Electric Dryer
Describe your 4E problem in samsung front load Problem
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
My 7kg samsung washer always flashes error code 4E now... please give me the solution...
Jul 04, 2009 | Electrolux EW1200i Front Load Washer /...
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
