Question about MarWare UpSurge Mini Speakers
Marware mini speakers only work when connected to hard drive
I have had the speakers connected to my hard drive all day to charge and still not working with my Kindle Fire HD unless hooked up to my hard drive. Not very portable :P
  • MarWare Master
  • 3,320 Answers
Use an AC Usb charger.
Find out how to reset the speakers.
And it's computer, not hard drive.
Posted on Apr 23, 2014
Only works when connected to my computer
Yes, posting the same question twice gets twice as many answers.
Apr 22, 2014 | MarWare UpSurge Mini Speakers
My bose soundlink mini won't charge or turn on worked fine for a while but now the red battery light is flashing fast every time I try to charge it it's been on the charger overnight and is still doin so...
I love my Bose Soundlink Mini 2. But, I faced a few issues sometimes.
Speaker not turning ONSpeaker not charging with the battery LED blinking.Speaker not getting connected to the bluetooth devices.
But all were fixed by reading through the Manual a bit. To help others, I actually made a video, to show some troubleshooting tips for the Bose Soundlink Mini 2. Checkout the video, if your speaker is not turning ON / not charging / bluetooth not getting connected:
This seems like a very common issue for the soundlink mini 2. This is due to a firmware bug. Gets foxed with a hard reset.Check the video for details and other trouble shooting tips.
Feb 22, 2014 | Cameras
Mac mini replace hard drive
You have to prepare the hard drive first in Disk Utility. Format it to accept an OSX install.
Aug 21, 2012 | Apple Mac mini Intel Core Solo...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Itunes cannot detect my ipod when i try and sync music to it
Uninstall the softwear that came with your ipod and Reinstall it.
Sep 01, 2009 | MarWare Docking Station for iPod shuffle...
Ipod won't work!!
I have solved it the problem is i downloaded music just into the my music libarary and not actually on to my ipod so it ment that there was no music on the unit lol!
Aug 25, 2009 | MarWare Docking Station for iPod shuffle...
Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
MarWare UpSurge Mini Speakers Logo
104 people viewed this question
Top MarWare Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MarWare Audio Player and Recorder Expert? Answer questions, earn points and help others
