The agitator will not move the washer works but the clothes just sit there
  • alayne58 Jun 22, 2009
    Kenmore Elite top loader. It makes a griding noise when it is agitating. I can stop it from moving with my hand. I took out the agitator and the spline looks great. I think it is what drives it from the bottom. Is there a belt?
    President:
  • 1,136 Answers
Hi, What make/Model# is this? I can help you.
Vic
Posted on Jun 20, 2009
  • Victor
    Victor Jun 23, 2009
    Hi, No there is no belt, This is a direct drive model. There is a coupler that connects the motor and transmission. if the coupler goes bad, it will not spin dry either, If it spins and doesn't wash, it must be the transmission.
    Does this help?
Lg waveforce top load washer that is around 3yrs old. The agitator plate hold down screw (under the chrome cap) keeps coming loose and at the end of the wash the plate is up with clothes under it.
Remove the screw and look underneath the agitator, GE machines have a correct way to put them back so the agitator sits at the bottom of the machine with virtually no gap. Tighten the screw hard. Perhaps you lost a locking washer at some stage?
We moved to front loaders.
Oct 24, 2015 | LG Washing Machines
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
UPPER AGITOR DOES NOT WORK WHEN WASHER IS FULL OF CLOTHES
replace the dog ears in the top section of your agitator can get from Repairclinic.com
Mar 01, 2010 | Washing Machines
Agitator doesn't move unless cap is tightened.
There is a metal piece that is inside the plastic agitator that is broken. I connects the agitator to the rod that drives it. It has an oval shaped slot inside and is ribbed on the outside. I have the same problem. Simple to replace, I just need to find the part.
Dec 28, 2009 | Frigidaire FGX831CS Top Load Stacked...
WCSR4170 not agitating
am I to believe that this is a agitator that sits on top of a spindle if so then try and move it by hand as some times the worm and gear cog in the gearbox become sheared or the drive belt is worn and slip easily not giving the power to the agitator I hope that's a start to go on eric
Dec 24, 2017 | General Electric WCSR4170D Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Top Agitator is not moving
This washer has a set of cheap plastic dogs that grab the inside wall of the upper agitator to move the clothes downward and help them get a better cleaning. The older style These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place. The newer style you simply pop the cover of the agitator and use a 3/4 drive extention to unscrew the upper agitator. replace the dogs and put the top back on. Nothing could be easier.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2008 | Estate TAWS800JQ Top Load Washer
Does wash clothes
depending on what washer u have this could be a sign that your carbon brushes are on there last legs not much to replace them but need to know what make off washer it is hun peter
May 27, 2008 | Washing Machines
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
