Question about Dryers
LG Sensor Dryer check filter - Dryers
3 Suggested Answers
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
ginko
  • 19396 Answers
SOURCE: LG DLE7177 electric Dryer will
Hi.
There is no fuse. If there is no power at all, then first diagnostic is done reading power from power cord and power at control assembly.
If the dryer is not starting test thermostats and door latch. Door latch is tested by jumping its contacts. Thermostats are tested reading Ohms to ensure that they have continuity at room (circuit not open).
Here Parts Breakdown.
Parts and diagrams are also available from Sears:DLE7177RM
Here thermostats.
Here door switch (part 330 in diag).
Posted on Aug 08, 2010
Check filter blinking on LG dryer and dryer won't start
There is a sensor at the bottom of the filter slot and it could be bad or plugged with lint. The whole service manual is here: http://www.manualslib.com/manual/974184/Lg-Dlex5101w.html?page=45#manual
It is going to show you the page with that sensor, but you can look at all the pages, I suggest page 23 for diagnostic tests.
Jul 30, 2016 | LG 7.3 cu. ft. Electric Steam Dryer, White...
My dryer Lg Tromm model number DLG5988 is blowing cold air, changed sensor bars still not drying- also the check filter light stays on and it's in cool mode and dry keeps blinking, what could it be?
sensor bars just measure humidity so dryer knows when close are dry, so will have no effect on heating. the check filter light is just a reminder, not connecter to any sensor or anything. could be several issues: gas valve solenoids, thermal fuses, etc. but for a quick try that might work, try just unplugging the dryer, push and hold the on button for about 20 seconds and then plug back in and see if the dryer is reset. works sometimes. good luck
Aug 24, 2015 | LG Dryers
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
SMART SENSOR SAYS CHECK FILTER BUT THERE IS NOTHING IN THE FIRLTER
It could be the vent hose in the rear is constricted. Check to make sure all hoses going in the rear are in good shape. Nothing constricted, nothing pinched, etc. If it's not that, check to make sure they aren't clogged.
Oct 09, 2012 | LG WM3987HW Laundry : Dryers :...
LG Tromm DLE2514W electric dryer: check filter light comes on when you turn the dryer on, but it otherwise seems to be working fine. The filter has been cleaned and the external house vent does not appear...
I suggest that you check the dryer venting hose and see if it might be clogged. You don't want to use the dryer with the filter light on. It could indicate a situation that could lead to a possible fire.
Oct 02, 2017 | LG Dryers
Our LG DLE0442W electric dryer is now flashing the Check Filter light and will start, but only run for about 5 minutes before shutting off. I have cleaned the lint trap completely and have also tried...
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Feb 21, 2011 | LG DLE0442 Electric Dryer
The check filter light is on. The clothes are not
The check filter light, is default message LG was put in place. No problem there. As for the clothes, I'd need some more infomation, what settings are you using on your dryer? I'll need to know if your using sensor dry, or manual dry.
Jan 30, 2010 | LG DLE5932W Electric Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Dryer LG DLE5955w
Jun 23, 2009 | LG DLE5955 Dryer
Dryers Logo
Top Dryers Experts
