Question about MarWare UpSurge Mini Speakers
Only works when connected to my computer
I can't get it to work except when connected to hard drive no matter how long I leave it there to charge. I bought it to use with my Kindle Fire HD.
  • MarWare Master
  • 3,320 Answers
Yes, posting the same question twice gets twice as many answers.
Posted on Apr 23, 2014
How do I fix a problem were a tower computer won't see the slave hard drive.
It sounds like both drives are trying to be the master on the cable. Have you tried setting both drives jumpers to the CABLE SELECT setting. This allows the BIOS to individually identify them and you specify in the BIOS which is the primary boot drive.
Mar 22, 2016 | Dell Computers & Internet
Marware mini speakers only work when connected to hard drive
Use an AC Usb charger.
Find out how to reset the speakers.
And it's computer, not hard drive.
Apr 22, 2014 | MarWare UpSurge Mini Speakers
Spinning wheel death
a new computer? how old is the computer your using and how old is the external hard drive? chances are either the computers pulling every gram of memory out in an attempt to search the hard drive for what you want leaving nothing for you to do other work with. might be upgrade time if its getting on in age.
if the hard drives ageing your going to be better off turning your external drive back into an internal one if you have a tower. you should have room to mount at least 2 drives into the tower. just buy a new hard drive connector and plug it up. the older USB drives work a good bit faster directly connected to the system.
Feb 14, 2014 | LaCie Computers & Internet
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
After connecting usbs, maxtor drive does not show up on pc screen. Therefore cannot see any files at all !!!! declan
Make sure you are connecting to a usb port directly on your pc and not through a usb hub. If that does not work try another usb port on the back of your pc. Also make sure the power supply to the hard drive is working. If that fails try looking for the drive in "My Computer or Computer" and if not there check in "disk management". Also try disconnecting all other usb devices except your keyboard and mouse reboot and then try connecting the maxtor drive.
Thanks for using FixYa
Jul 04, 2011 | Maxtor Computers & Internet
No system disk has been found, insert CD and press any key to continue. There is a black screen on my PC, no matter what CD I put in, or pressing any key, the message above just appear again on the...
this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Mar 31, 2011 | Computers & Internet
No matter how long I leave my computer plugged in, the battery won't charge more than 80%.
OK, I had the same problem as you have, except the battery wouldn't charge beyond 0%.
Sounds like you need to buy a new battery for the netbook.
Jan 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
My sansa Express won't charge or connect to my computer!
try leaving it in the computer charging over night... if that doesnt work, call custumer care!
Jul 22, 2009 | SanDisk Sansa MP3 Player
Laptop won't boot up properly
Connect your computers to an external monitor and press the appropriate F key combination (Shift + F7) to switch video output to the monitor. If you see an image on your monitor you have a bad LCD screen or back light inverter. If not you need a new motherboard. Guy that gets ticks, you need a new motherboard anyway.
Feb 18, 2009 | Acer Aspire 9300 Notebook
MarWare UpSurge Mini Speakers Logo
79 people viewed this question
Top MarWare Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MarWare Audio Player and Recorder Expert? Answer questions, earn points and help others
