Question about Peak Performance Rechargeable Led Lamp Pkcota 30 Led Light Cordless Flashlight
I need to know the charging volts and mA for my Peak Performance Rechargeable Pkcota light
  • 35 Answers
I believe those lamps from Peak are at 12v, iv seen them before at Auto stores
Posted on Apr 22, 2014
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
May 20, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
How do you replace light in Peak rechargeable spotlight
Sorry I don't know how to change the lights, but I need to know the charger volts and mA. Could you look at your charger and let me know please? ian 83877 at gmail
Jan 18, 2014 | Peak Performance Rechargeable Led Lamp...
12 volt rechargeable battery for child's riding toy
usually the charger has an indictaor light on it that is red/amber when its charging and then green when the battery is fully charged. does yours have this light?
May 14, 2012 | Peg Perego 12 Volt Rechargeable Battery
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
What is the max mA battery rating that can charged by the Bc700?
Divide the mA of the battery by the mA you want to charge it at.For example,I'll use the 3000mA battery at a 500mA charge.That would be 6 hours.However,that only actually charges it to 80%(for alkaline).It needs another 6 hours to charge the remaining 20%.If they are not alkaline let me know and I will look and see what I can find out.
May 07, 2010 | La Crosse Bc700 Alphapower Battery Charger...
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
MOTOROLA T5522 BATERIES
Hello mironas3,
A general rule of thumb when dealing with rechargeable battery packs is to take the capacity of the battery divided by the charge rating of the charger and then add an additional 10%.
Offhand I am not sure what the voltage / capacity or voltage / charge rating of the battery and charger are but you can determine that by examine the labels on both items. Let’s say (for example) that your battery is listed as 7.2 volts and 1,000 mAH and your charger is rated as 9 volts and 100 mA. (These are just theoretical examples. Substitute the numbers from your own items.) You would divide 1,000 mAH by 100 mA to equal 10 hours. Then add 10%. So you expect a full charge to take around 11 hours time.
Of course, actual charge time will vary depending on how discharged the batteries are when you start charging them. Since the charger that Motorola provided doesn't have a charge indicator determining when the batteries are done charging is a matter of making an educated guess. If you touch the batteries while they are charging and they feel warm to the touch, that's a pretty good indication that they are done or nearly done charging as once the batteries are topped off excess power will turn into heat. (Note that batteries in a charger should never be HOT. If they are ever more then just slightly warm, something is wrong with the battery or the charger or both.)
Also, just a word of warning here: remember to always use the correct manufacturer recommended charger. Substituting a charger with twice the charge rate to charge the batteries in half the time is not a good idea. Rechargeable batteries are meant to be charged slowly. Fast chargers exist but they typically have built-in circuitry that pulses the charge rate to prevent the batteries from overheating. Using the wrong charger can result in damage to your battery or radio or worse could possibly even lead to a fire.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 28, 2008 | Motorola T5522 (7 Channels) 2-Way Radio
Peak Performance Rechargeable Led Lamp Pkcota 30 Led Light Cordless Flashlight Logo
150 people viewed this question
Top Peak Performance Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Peak Performance Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
