Question about Electrolux Vacuums
Electrolux EL 4101 canister vacuum won't **** up anything
Filters and bag changed. Hardly any suction.l
LizDahl
  • 75 Answers
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
  • 97 Answers
SOURCE: Electrolux Canister - Renaissance model
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
Posted on Aug 07, 2008
defrankond
  • 65 Answers
SOURCE: Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Posted on Nov 29, 2008
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Oxygen Canister doesn't work.
something is blocked/clogged up check the filters.adrian,,,,
Jul 07, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How to use the after filters for the electrolux canister vacuum
At the back of the vac on top you will have a removable grille. Release the thumb tab to lift the grill.Older models had this tab at the back of the grille. The filters will sit underneath. They should clip into the round exhaust opening. Then replace the grille. Change filters every 6 bags. More often if you have pets or allergies.
Sep 12, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Volta ultima 2000 watt vacumn - hardly any suction at all
change your bag.or your motor is going bad so have that looked at.
Jul 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My electrolux is over ten years old now and doe not have much suction. Changed the bar still no suction or very little. What gives? Wjymw
I am the Sales Coordinator with Electrolux, and personally it sounds to me like your machine could use a service check. Your local Aerus/ Electrolux office should be able to help you out with that no problem. If you are having trouble reaching them feel free to call my office (570)326-1731 and ask for Liz. I hope this is able to help you out.
Dec 25, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
55 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
