Question about Makita Ls1216lx 12" Portable Dual Slide Compound Miter Chop Saw W/ Stand
LS1216 is stuck on a bevel
I just took it out of the box, and turned it to the 22.5 degree bevel, and it's STUCK there. I've tried and tried to depress the unlocking button back there, tried fooling with the locking lever, and it's just stuck. I just shelled out a LOT of money for this thing, and it screws up right out of the box.
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: bevel locking lever won't tighten
It looks like that handle should be able to pull straight off the end of the shaft once you remove the screw. See this exploded parts view: http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
My experience with them is that people tend to get frustrated and abandon the lock lever and just run the saw "loose". Scary as it sounds, I've seen it on more than one site.
Anyway, I don't have a fix for you if you can't get the handle off to re-position it.
Makita does have a tech support line if you want to give it a try. Otherwise, you may have to shell out a few bucks to one of their service centers. We used to have a great one in Albuquerque, but it's now defunct. People don't seem to repair tools like they used to...
Locate Nearest Service Center online
or Free technical support center (1-800-4MAKITA)
Monday – Friday 7:00am – 7:00pm EST
Good luck, and best wishes...
Posted on Mar 28, 2009
  • 10865 Answers
SOURCE: my LS1216 slide compound miter saws mitering table
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Posted on Feb 06, 2011
SOURCE: JR3050T blade lock lever is stuck
i lossened the screw on the guard and the lock returned to the lock position and thanthe screw that is the bib screw
Posted on Nov 07, 2011
I have reverse but no forward took apart no chiped or brocken gears replaced bearens on small gear shaft shimed top beveled gear still does same thing
should of mentioned the make and model...
also check the belt tensioner arm... they'll get stuck and not apply pressure in forward but in reverse... also seen it do it the other way around...
Apr 28, 2015 | Garden
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Kitchenaid Artisan Stand Mixer has stuck hub bevel gear (KSM150PS)
The bevel gear sits above the worm-follower gear. I think you mean the drive attachment gear.
I think I have the same, or similar problem. I ground a piece of meat that stopped it from working. The drive-attachment-gear turns if I push it in, but then it pops out. I am still trying to figure out what part is causing the issue - the drive attachment gear, or maybe even the worm follower gear.
Feb 24, 2013 | KitchenAid KSM150PSGR - Artisan Series...
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Joe
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
I have purchased a dewalt 718, 12 inch sliding double bevel saw , private sale, saw was only used a couple of times and is in new condition .Checked cutting bevels and found that the left 45 degree does...
The fence may be getting in the way of the arm when you adjust the trunion assembly fully to one side or the other for bevel cutting. Adjusting the fence all the way out away from the trunion assy. should allow full 45deg adjustment. If this is not the case, it could be--even though its only slightly used--that there is sawdust built up enough in the housing to keep the arm from fully adjusting.
While the latch COULD indeed be faulty, it generally should always be tightened/locked so that the trunion assy. is fimly "locked" before cutting as this is designed to keep the saw from shifting mid cut, causing binding, uneven cuts, broken blades, seized bearings, etc.
Dec 02, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
Makita Ls1216lx 12" Portable Dual Slide Compound Miter Chop Saw W/ Stand Logo
14 people viewed this question
Top Makita Electrical Supplies Experts
obsteiner
Tom Chichester
Ogbonna promise
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
