Question about Olympus DM-20 Digital Voice Recorder
Olympus dm-20 when I click on a folder, the voice file list box does not populate but says there are files in the folder
In the download tray and the device manager the files are listed but when I click on any of the folders, the list of voice files does not fill in the Voice File LIst Box on the right side.
JULIANFIX
  • 975 Answers
SOURCE: Where can I obtain the software for the Olympus DS 330 voice recorder that is required to be able to download files to my PC
go to this link:
http://www.olympus-europa.com/consumer/2590_3505.htm?prodID=P_053011 , hope this helpful
Posted on Apr 27, 2008
SOURCE: olympus vn-2100pc
check out this link, i had exactly the same problem but this blogger has a working patch for the vn-2100pc and vista - works fine now!!
http://blog.ironguard.net/2007/06/olympus-vn-2100pc-and-windows-vista.html
Posted on May 20, 2008
  • 919 Answers
SOURCE: i have olympus digital voice
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window make sure the CD drive the digital wave player disk is located and is listed in the window
12. Check the "include subfolders" box.
13. Click Next
A security warning window will open,
14. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You
will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Dec 09, 2008
  • 919 Answers
SOURCE: Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
Posted on Dec 11, 2008
ADSupport
  • 9 Answers
SOURCE: Olympus DSS Player Pro Woes!
There is a small utility called dssclean, which can fix these files for you. Check with your Olympus Pro dealer, as they should be able to provide that for you.
Files usually get this way when a computer or the Transcription Module crashed while a file is open. The system doesn't get a chance to close the file and it remains in "typing mode."
The other, more readily available work around, is to select the file in the Transcription Module, then go to File > Convert File and convert it to a WAV file (it actually only makes a copy of the file). You can then transcribe the WAV file and delete the locked file.
Posted on Dec 30, 2008
Files gone! took batteries out by mistake?
Check out this link to Olympus for a PDF manual and software downloads for your product. Just copy and paste into your browser.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1270
Hope this helps, let me know if I can help you with anything else.
JimmyC
Oct 06, 2009 | Olympus DM-20 Digital Voice Recorder
DM-10 reverted to japanese
To reset the settings back to English:
1. Set the DM-10 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-10 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-10 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Jan 09, 2009 | Olympus DM-10 Handheld Digital Voice...
DS3300 when plugged in doesnt automatically download VFs
check the services to see if the dm1 service is started
Oct 23, 2008 | Olympus DS-30 Digital Voice Recorder
Oct 16, 2008 | Olympus DM-20 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Putting recorded files on I-Tunes
download windows media player for mac from the microsoft website or you may download flip4mac to get the files to play on your mac
May 26, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus DM-10 trouble
When I turn on the recorder It says "memory trouble", even after I formatted both the music and voice folders. Sometimes the "Memory trouble" shows while I record Physiology class,Resulting in stopping the recording.
I would be very grateful for any assistance concerning this.
Thank You
Jonathan
Mar 05, 2008 | Olympus DM-10 Digital Voice Recorder
Download Files
Hi, I had this problem using a Olympus DS-2300 recorder. I installed the DSS Player Software on my PC and when I tried to download the files from my device to the PC I had this problem.
You will need to check the location of a file called DSSjobNo.dat. The application I think tries to copy this file into the default location for the Download folder, usually somewhere in your My Documents. If it can't copy the file there for some reason then that will stuff things up.
To check where the application is expecting the file you will need to check a value in the registry. This maybe a little tricky so get someone who knows there way around the registry to help you. The location of the entry is HKCU\Software\Olympus\DSSPlayer2002\Dictation Module\download\InstallSetting The value is JobNoFilePath and will hold the path to where the application is expecting the dssjobno.dat file.
Armed with this knowledge you can then check if the dssjobNo.dat file is in that location. If not copy the file from C:\program Files\olympus\DssPlayer (this is where I found the file on my PC) to the location the registry entry specified.
Or if you know what you are doing you can change the reg entry to go to the location you want the file to be in. Useful in my case as I wanted the download path for my files to be on a shared folder on the network and I wanted to keep it all together.
Hope this helps!
Mar 02, 2008 | Olympus DM-10 Digital Voice Recorder
How do I Change from default language back to English?
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
Apr 07, 2007 | Olympus DM-20 Digital Voice Recorder
Olympus DM-20 Digital Voice Recorder Logo
29 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
