Question about Dell Dimension 4700 PC Desktop
A and e lights are green b and c are amber
Ithr error
    Problem Solver:
  • 9 Answers
Ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4700_service%20manual_en-us.pdf
Posted on Apr 23, 2014
3 Suggested Answers
  • 998 Answers
SOURCE: Loooong boot time
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Flashing amber light on printer
As you give print command check what is the error msg flashes on ur PC.
Next check whether any paper piece is jammed inside the printer, dust it with Airblower so that cleans out.
Third check the ink levels in both color and black cartdriges.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Loooong boot time
Thank You.
Nov 10, 2008 | Dell Dimension 8400 PC Desktop
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Green-Amber-Amber Code?
I know that my post is very belated, but I think, will be helpfull for someone henceforth...
First of all, there is one "chronic" problem with LG monitors: solders. Check soldering of Video Amplifier IC303, Flyback Transformer, Q833( ! 210V) , deflection coils socket, Vertical IC601, XTAL X401 and so on...
In Your case, probably the cause of "green, amber, amber" lights is lack of 15V on the Verical Amplifier IC601. DPMS is activated, and monitor does not work at all, even power off.
Replacing Q912 (2SA1273) solve the problem. I replaced him with 2SA1680 PNP 1A 900mW 60V, and all is OK.
This problem is fundamental for ALL 17'' Flatron monitors, repaired by me (over 30).
Wish Happy Repairing!
Best regards, Ico.
Sep 14, 2006 | LG Flatron F700P 17" CRT Monitor
Dell Dimension 4700 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
