Question about Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor
Bad pressure switch
Need replacement pressure switch for ac0306hpc/03941 pancake air compressor
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
Unit has developed a continuous leak
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Sep 06, 2012 | Clarke Power Products Inc AC2001 2HP 4...
I have a husky 5gal. oilless pancake compressor it leaks air around outlet tube/hose rite at the pressure switch housing. How do you fix the line
You have to replace defective hose. Buy and fit a better / higher pressure range to prevent this condition. Check also all your hose connector for malfunction.
Regards
Apr 26, 2011 | Air Tools & Compressors
Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
Aug 01, 2010 | Air Tools & Compressors
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Compressor won't start!
Try adjusting the pressure regulator to a higher out put pressure. My friend had one the tank was full but the regulator was shut off and it would start until air was allowed out of the tank droping pressure below 90-100psi the low limit of the cut in/out switch
Sep 20, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
My air compressor (pancake task force) cycles on and off at around 100 psi. Is this an adjustment or could the pressure switch be bad? Could not find my particular compressor in the product listing.
EITHER YOUR PRESSURE SWITCH IS BAD OR YOUR TANK IS COMPLETELY FULL OF WATER AND THERE IS LITTLE ROOM FOR AIR. ALWAYS TAKE YOUR SWITCH WITH YOU WHEN PURCHASING A REPLACEMENT.
Apr 03, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor Logo
81 people viewed this question
Top Hdc Homer Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Hdc Homer Air Tool and Compressor Expert? Answer questions, earn points and help others
