Question about Sanyo DP50747 50 in. Plasma TV
I have a 55 inch vizio flat screen. it turns on but the screen fades away.
  • Sanyo Master
  • 3,320 Answers
//If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 23, 2014
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
Vizio TV has a horizontal 2mm black/multicolor line.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
I have a 55 inch Vizio Edge Lit Razor with apps when I go to the you tube it starts playing then screen go blank
Hello, this may be a software glitch, contact Vizio to see if there is a software update. thanks, Terry
Oct 09, 2012 | Vizio M550NV 55 in LCD HDTV
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
My picture fades in and out. Sometimes there is no picture at all but the sound is still there.Have not had the tv but 30 days
Now tv is on,u have a picture only few sec.and faded away and have audio left only?Yes then the tv have 2 long board call LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.Tv is newly bought?Return it right away for an exchange for a diffrence new one.
Dec 21, 2010 | Vizio VF550M 55 in. LCD HDTV
Vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
Aug 14, 2009 | Vizio VOJ370F 37 in. LCD TV
Sanyo DP50747 50 in. Plasma TV Logo
69 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
