Question about Canon imageRUNNER 5000 Copier
Print or scan thru USB port on Canon image runner 3230
  • 168 Answers
SOURCE: Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Posted on Dec 17, 2008
  • 135 Answers
SOURCE: Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Posted on Apr 19, 2009
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
  • 61 Answers
SOURCE: need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Posted on Oct 24, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
IR C5180 Will scan to a computer but will not print from a computer.
Have you checked that your printer driver is correct and that the IP Address for the driver and the machine are the same?
Aug 03, 2012 | Canon Office Equipment & Supplies
I have canon image runner 3035. I want to know to know how to scan
you can find manuals here:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2230_2230g_2270_2830_2870_3530_3025_3030_3035_3045_3530g_3570_4570/imagerunner_3035#BrochuresAndManuals
Jul 25, 2010 | Office Equipment & Supplies
Canon Image runner 2270
There is just know way to walk you thru this. Your going to need someone with the know how to come to your location to set up your scan option. Your local canon dealer can help you.
May 19, 2010 | Canon imageRUNNER 2200
How do I get the Canon image runner 1023if to scan documents? I have followed the instructions provided by Canon (what little there was) loaded the drivers, (as per Canon) and still cannot get past the...
Try using different software for scanning. e.g. Photoshop Select the right scanner, for Canon you usually see WIA. Then import image and select Canon. New window will pop-out and you can start scanning. Be sure to press the SCAN button of the machine before scanning.
Jan 26, 2010 | Canon imageRUNNER 1023iF Black and White...
Apr 08, 2009 | Canon imageRUNNER 3035 Black and White...
Printing on a Canon Image Runner 5000
go here and download the PCL5 driver for Windows XP (NOT THE 64 BIT version though):
http://www.canon.ca/english/index-softwaredownload.asp
The driver is the same regardless of the port. Just select "local" port when setting up.
Feb 13, 2009 | Canon imageRUNNER 5000 Copier
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 5000 Copier Logo
24 people viewed this question
old marine
old marine
