Tv comes on but screen fades away
50 inch viseo flat screen
  • 3,320 Answers
...If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 23, 2014
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
  • 2336 Answers
SOURCE: No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Posted on Mar 21, 2008
SOURCE: 3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Posted on Jun 05, 2008
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
I have a 55 inch vizio flat screen. it turns on but the screen fades away.
//If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
Apr 22, 2014 | Sanyo DP50747 50 in. Plasma TV
I have a new 37 inch led/led samsung tv. picture is larger than screen size by about 20 % how do i reduce it to screen size.
should be a button on the remote that says "P.Size" Every push of the button changes the Aspect, should be set to either 16:9 or Full. Hope this helps. If you do not have the remote, you can access thru the menu button on the set and toggle thru on screen display to Viseo and adjust it there as well. Hope this helps.
Jan 11, 2011 | Samsung Televison & Video
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
