Question about Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor
Pressure switch for ac306hpc/03941 pancake air compressor
Replacement part wanted for above compressor
Can I replace the tank drain on my Porter Cable 150PSI 6Gal pancake compressor with a ball valve?
As long as it will physically fit and the rating is above 150psi -Yes.
I say above 150psi because if the compressor pumps to 150psi, a 150psi valve is on the hairy edge of it's max limit.
Oct 13, 2017 | Porter Cable Air Tools & Compressors
I have Ingersoll rand ssr Hp40 SE compressor.. I can't set pressure above 95 psi if it have discharge pressure 143psi..what should I do for set this? If pressure touches 95 psi automatically vavle...
The tank, compressor head, and components need be rated at what you want set the compressor unit pressure to, the safety valve will keep from exceeding the lowest of those limits. If you suspect the safety relief valve needs replacing because it has weakened, then replace the safety valve with one OEM pressure values
Aug 09, 2017 | Ingersoll Rand Air Tools & Compressors
How to replace a/c compressor on 2007 mazda cx-7?
2009 Mazda 3 AC Compressor Replacement
The above link is for a 2009 compressor replacement, but it should help with your 2007.
May 01, 2014 | Mazda CX-7 Cars & Trucks
Want to know where the crank sensor is located on a 2002 F-550 Super duty 7.3 Diesel
Crankshaft Position Sensor: Front of the engine, above the crankshaft damper. Front of the engine, passenger side of the crankshaft pulley.
Good luck.
May 29, 2011 | 2002 Ford Super Duty F 550
Do you know where I can get a wiring diagram on a whirlpool side by side refrigerator model no ED5PHEXMB00? Mainly for the compressor. Freezer is not getting cold. I vacuumed the coils in front and...
Hello Thayden,
I understand that the Refrigerator compressor is not working on your unit. There are three possibilities of why the compressor is not working, the compressor is bad, the starter is bad, or the capacitor is bad.
To check the starter you will need to do the following (most common): Refer to picture at the bottom of the post
1. Unplug the unit
2. On the side of your compressor there is a cover this is the starter relay cover.
3. Remove the cover
4. Remove the wires
5. Remove the starter (top piece stuck on two rods)
6. Check if bad (shack it if you hear a noise/knocking it is bad and will not allow compressor to start)
7. Replace it and the bottom one the over load.
8. Reinstall in reverse
The Run Capacitor (uncommon that they go bad but possible)
1. The little black or silver box that two wires run to from the starter
2. Check to see if contacts or unit is burnt.
The Compressor
1. If you replace the above items and the compressor is not running the the problem is the compressor. This will take a licensed HVAC person to replace.
The above parts are inexpensive between $30-$50 at your local appliance parts store. There is a 50/50 chance that this will work and save you the cost of replacing the compressor or the whole refrigerator.
Thank you for choosing FIxYa.com
Justin
pd_0046_106_4387835?$pddetailsth$
Above Starter/overload and cover replacements (starter is in the bottom middle that you shake to see if you hear a noice/clicking)
Starter relay box on the left side of the compressor in this image.
Apr 05, 2011 | Whirlpool Refrigerators
I HAVE A 2 HORSE POWER COMPRESSOR (QUINCY) WHEN I TURN ON THE UNIT THE AIR REACHES 80 LBS AND KICKS THE PRESSURE RELEASE VALUE IN OTHER WORDS THE COMPRESSOR WANTS TO RUN ALL THE TIME AND NOT SHUT OFF...
Replace the pressure release valve, Typically they are set to protect at above 130, depending on the specs for your machine. This is a safety device, intended to not normally release...
Always look for leaks when you are working on the unit.
Feb 25, 2011 | Computers & Internet
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Psi will not go above 40 psi tank presuure will not go above 20ps
chech air filters for restrictions if not compressor internal parts worn!!!Good Luck to You!!!!
Jun 27, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My chest freezer is warm what can be the problem?
there coud be many possiblity:
check wheather the compressor is getting current or not.
check the running amper of the compressor with a multi meter.
the reading must be 0.6 to 1.1 if it is coming above 1.1 to 4.2 than your starter have the problem. if it is showing 4.6 or above than its time to replace your compressor..................have a nice day :-)
May 14, 2009 | Kenmore Freezers
Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor Logo
122 people viewed this question
Top Hdc Homer Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Hdc Homer Air Tool and Compressor Expert? Answer questions, earn points and help others
