Sharp mini component system cd ba300 error cd 11
zair
  • 82 Answers
SOURCE: Sharp CD-BA300
An audio output IC may be defective. This set carries two output IC's.
Posted on Mar 24, 2008
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
SOURCE: display says protect
check your low voltage fuses, the protect light up when a overload comes....
Posted on Jan 30, 2009
SOURCE: Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Posted on Oct 27, 2009
  • 4234 Answers
SOURCE: Sharp CD-BA300 stereo system went into Protect
These units use AMP-PACs for the final amplification stages. This part is defective. The protect message indicates that there is an internal problem and the unit is shutdown to prevent further damage. The part numbers are listed below with the costs. These parts can be purchased from tritronicsinc.com. Use the guest account to access them.
Parts:
VHISTK40271-1 $58.28
VHISTK4029S-1 $63.32
Dan
Posted on Nov 17, 2009
I need a FM antenna X 1 (92LFANT1535A) for Sharp Mini Component System model CD-DK890N
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Sharp+mini+cd-dk890n+parts&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.partstore.com/Model/Sharp/Sharp/CDDK890N.aspx
Jan 20, 2013 | Audio Players & Recorders
Cd-ba3001 manual sercvicio
HI,
PLEASE GO TO THE GIVEN LINK ,HERE U CAN DOWNLOAD pdf file.
THE LINK IS :-
www.audiolabga.com/pdf/32SC260.pdf
I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE DON,T FORGET TO VOTE ME.
GOODLUCK.................
Feb 02, 2011 | Sharp CD-BA300 CD Shelf System
Sharp CD-BA300 stereo system went into Protect Mode. When I power up all it does is display PROTECT. How do I clear it.
1 suspect speaker defect
2. suspect wiring defect ensure all your wires are connected up properly and your speaker are in good order
3. suspect that the cooler fan may be blocked and the system is overheating. use vacuum cleaner on air vents to remove dust.
4 see specialist as this product maybe defective.
Nov 17, 2009 | Sharp CD-BA300 CD Shelf System
"PROTECT" in Display
Probably your output amp. is worn out
Feb 19, 2008 | Sharp CD-BA300 CD Shelf System
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Sharp CD-BA300
Aug 14, 2007 | Sharp CD-BA300 CD Shelf System
46 people viewed this question
 Grubhead
Grubhead
