Question about Jensen CD-335X CD Player
Jvckds39 to 96 cavalier sterio
Trying to hook new sterio to 96 cavalier
I have a phillips mx 3900d five disk surround sound system, however I cannot figure out for the life of me how to hook it up to my xbox 360.
Well if hooking Xbox with rca jacks it came with..plug in the red and white one to the sterio.. or run rca jacks from back of TV..red and white from TV out..or audio out..to sterio..
Aug 15, 2014 | Video Game Consoles & Games
No sound
Make sure the wiring is proper.. Are all you wiring a brand new player into your car? If yes here's the wiring procedure..
all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Apr 12, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Need to know the color code on sterio to hook up a new one it is a 98 voyager sterio cassett
Try this link, it should help.
http://www.the12volt.com/installbay/stereodetail/676.html
Jul 30, 2010 | 1998 Plymouth Voyager
I just got a new battery and a new alternator and my car died. How do i fix this???
well this is just a guess but if u have a big pounding sterio you will need a bigger alt if not have the car diagnostic tested at a gm dealer for 80 bucks theyll let u know whats up
Aug 19, 2009 | 2001 Chevrolet Cavalier
Ow do i hook it up to my home sterio system?
Not really possible, as a car amp requires a remote signal (usually a 'pulse' of 5 to 6 volts), to turn on.
Maybe you could wire up a small homemade battery/switch box to the amp to pride the switch on signal?
Apr 12, 2009 | Lightning Audio B4.250.2 Car Amp
Sterio wireing
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
Apr 07, 2009 | 2000 Ford Focus
Kenwood sterio wont turn on
the short answer is yes... it's a theft prevention thing... try unhooking the battery again for a few minutes... the hooking it back up... i presume you have the code and know how to enter it ?
Robert
Please take a moment to rate this solution
Jan 26, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
I am installing an after market stereo deck into a 2004 Chevy Cavalier but I am not getting any power. From my research I need to hook the deck up to the vehicles ignition harness but I do not know where...
ok now this is fun i had a good ole time putting my after market raidio in on my 04 with out the $300 harness that the sterio shops wanna charge a arm and a leg to install you need to run your 12v power source to the igniton fuse its farly simple if you need picture diagrams i can deffianatly post some pictures showing you exactly how to wire it up bc trust me i was mad enuff trying to get my stereo in so i wouldnt mind helping some one else out on getting it installed bc its frustrating not knowing how to do it
Jul 19, 2008 | 2004 Chevrolet Cavalier
My sterio wont play all my dvd's or cd for all the money i paid for the sterio mant sterio shops say its commen after six months thats why they dont sell jenson products please prove them wrong and fix my...
try geting a disk cleaner or taking it apart and cleaning the lens with a q-tip dipped in rubbing alcohol just gently rub the lens in one direction and let it dry then hook it back up it should work then
Mar 31, 2008 | Audio Players & Recorders
Jensen CD-335X CD Player Logo
15 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
