Question about Windchaser Heating & Cooling
Need new venting hose
Current hose is falling apart. Where do I get a new one.
  • 884 Answers
Is it the same size as a tumble dryer venting hose? Could you not search online for a replacement?
Posted on Apr 30, 2014
The dryer overheats, stops and the door opens. when we take it apart the dryer is full of lint despite the venting system in good working order and has been checked
Hi psteel...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
Jun 04, 2011 | Dryers
Tip
Air not blowing out of vents in car?
The air not blowing out of the vents in a car but actually if you can hear that air is kicking but its not flowing out of the vents, then this can be the reason:--
  • There is a blend door and motor in the heater box.
  • The blend door motor comes on when you select a setting.
  • It actuates the blend door and directs the flow of air to the proper place.
There are two types of motor mostly seen in car heater box.
  • One is the motor powered electric automotive current.
  • And other is the motor powered by vacuum hoses.
in your car any of this motor can be there.
Many times the blend door gets stuck from debris that falls down through the vents. Also it is possible that the blend door motor is bad or simply came unplugged. Some of these motors are powered by electric automotive current and some are powered by vacuum hoses. It is possible for the vacuum hoses to break or become unplugged.
you will have to check all this options to locate the fault for what is stopping the air from flowing out of the car vents.
this will help.good luck.
on Feb 28, 2010 | Chevrolet Impala Cars & Trucks
When switching the a/c on the blower comes on, but sometimes no air comes out of vents
sounds like a blower motor resistor. Does it only do it at one speed or a couple or all
May 25, 2011 | 2003 GMC Safari
WHEN INSTALLING A DRYER, IF THE APARTMENT HAS NO WASHER DRYER CONNECTION, DOES THE DRYER NEED TO BE INSTALLED BY A WINDOW ?
not really; but the vent hose has to vent out side some how/ put the dryer where you want it run the vent hose to outside..good luck /joe/
Aug 26, 2010 | Whirlpool Dryers
My a/c is working, but 98% of the time only blows out of the defroster. Sometimes will split between defroster and floor when in any postion. If i turn the temp up & am stopped it will sometimes blow...
Controller runs on vacuum. You have a vacuum leak between the engine intake and the HVAC control switch or in the switch itself. First look for the vacuum source and hose in the engine compartment. if that is OK, open the dash to access the back of the climate control switch. Disconnect the hose set from the switch and check for vacuum on one of the lines--that would be your source vacuum. The switch will pass vacuum to different remote diaphrams to switch the doors in the system to deliver air to the various registers. If the switch is falling apart and leaking vacuum, you will need a new one.
Aug 23, 2010 | 2004 Ford Crown Victoria
Damp button stays on and it won't work. Water in the vent hose.
leave vent hose off, run dryer. if solves problem fix vent hose and vent. if not then take dryer apart and clean all the lint out
Jul 19, 2010 | Maytag EPICz Electric Dryer
Most vehicles today have what is called a blend door and motor in the heater box. The blend door motor comes on when you select a setting. It actuates the blend door and directs the floe of air to the proper place. Sometimes the blend door gets stuck from debris that falls down through the vents. Also it is possible that the blend door motor is bad or simply came unplugged. Some of these motors are powered by electric automotive current and some are powered by vacum hoses. It is possible for the vacum hoses to break or become unplugged. Check all these options. One of my kids dropped a comb down my upper vent and it blocked the blend door from directing the air flow. That was an easy fix and I hope yours is a simple. I hope this helped you. Roger
Feb 07, 2010 | 2004 Chevrolet Impala
When I accelorate my ac vent goes from center
Check the white vacuum hose going to your recirculation door outside under the hood. It is located on the passenger side firewall . The hose becomed brittle and falls apart. I get small vacuum hose and cut into the wiring harness to locate a good section of hose.Put hose to vacuum motor. Good luck.
Aug 09, 2009 | 1995 Ford F150 Styleside Regular Cab
Lost vacuum at defrost & vent & floor control.
It does not hook to throttle body , it hooks to a vacumn port on the intake manifold. Follow hose from cruise control module to the tee-three-way connector on firewall. Over time the tee will fall apart and will leak One hose goes to the vacumn port, one to cruise module,one to ac contols.
Jun 27, 2009 | 1994 Buick Skylark
Air not coming from the center vents just the ones on the sides? what can be the problem?
over time age gets to the vent hoses... on some vehicles the hoses dry rot and fall apart.. on others they may just somehow come undone... only real way to tell.... *shivers... is to take the dash apart.. :(
Sep 22, 2008 | 2003 Mitsubishi Diamante
Heating & Cooling Logo
77 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
