Question about HP LaserJet 9050 Printer
60.02 replacing a lifter drive assembly
  • 78 Answers
Here is a link to the manual in PDF format.
http://www.lbrty.com/tech/Manuals_HP/90x0sm.pdf
Posted on Apr 26, 2014
Dodge neon 2.0 L sohc how to remove lifters from rocker arms
Ok here is the deal, the lifters are poorly designed and prone to noise or "tick", the way to silence this is not just new lifters but new rocker arm assemblies which include new lifters. Use the best parts not the cheapest ones, factory new one are improved from previous designs. If you still want to just replace the lifters you must take the rockers to a machine shop and have the lifters pressed out and replaced by them. Another suggestion is if you live in a warm climate use 10W-30W synthetic oil.
Aug 30, 2016 | 1996 Dodge Neon
I was quoted $500 to replace all the lifters. Is this a good price?
That is a ridiculously high price to replace lifters on a 4 or 6 cylinder engine. On the Mitsubishi 4 cylinder motor, the only thing that is needed to do is remove the valve cover and remove the rocker rod. (2 rods which hold the rocker assembly.) Next is remove the lifters from the bottoms of the rockers and pop in the new ones. Be sure to soak the new lifters in oil for 24-48hrs prior to install so they are pre-filled before install. Replace the rocker assembly and torque down to specs. replace valve cover and then start the vehicle. Check that there is no loud tapping noise and do not race the engine until the lifters have pumped up with engine oil. You should replace oil and filter for this engine work as well.
Apr 17, 2015 | 1994 Mitsubishi Mighty Max
60.20 error
The tray 2 lifter-motor is not functioning
Unfortunatly this usually requiers parts
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness is full seated in its connector on the dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver assembly
-If the unit is still clicking/banging with a new lifter replace the tray -If the unit is still clicking/banging with a new lifter and tray see step 5 5 Replace the dc controller PCA.
Apr 22, 2014 | HP LaserJet 4350dtn Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Marca error 60,02
60.2
The tray 2 lifter-motor is not functioning.
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
Replacing Hydraulic Lifters
YOU HAVE TO REMOVE VALVE COVERS LOOSEN REMOVE ROCKER ARMS ASSEMBLY KEEP ROCKER ARM ASSEMBLY IN ORDER SO THEY GO BACK IN THE ORIGINAL POSITION.YOU HAVE TO REMOVE INTAKE MANIFOLD ALSO.YOU NEED A REPAIR MANUAL FOR TORQUE SEQUENCE ON THE INTAKE MANIFOLD AND ROCKER ARMS TORQUE.
May 27, 2010 | 1994 Dodge Stealth
How do I fix the lifters on my 2000 chrysler sebring lxi? Do I have to do anything special with them or just go buy them from autozone and replace them?
You need to change the cam as well and you will need to check each lifter to see if you need to change the rocker assembly. If the rocker Assembly is worn out that may be your only problem. The lifters if they leaked would rattle if they leaked down but after warming up would stop, however if they rattle all the time it could be just the rocker assembly worn out but would need to know which engine is in it as there are 4 listed for that unit.
Mar 23, 2010 | 2000 Chrysler Sebring
Oil not getting to back rocker, push rod clear. had a new head gasket put on, pulled head to see if it was put on backwards, it was not. how do you replace lifter.
Since you already have had it apart, you know at what point you can see the lifter. Lifter pulls straight up out of its bore, new one drops right in. If cam contact surface is worn concave, you need to replace cam as well. Always use assembly lube on lifter/cam contact surface when installing.
Apr 23, 2009 | 1990 Chevrolet S 10 4WD
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
assembly.
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
Error 60 02 on a HP LJ 4250DTN
60.2
printer error
assembly.
Jan 10, 2008 | HP LaserJet 4250dtn Printer
HP LaserJet 9050 Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
