Recording probs Has suddenly stooped recording serials, when I try to record again (shows no red underlining) it tells me that recording has already been requested but still doesn't work. Also some recordings are fromBBC Wales instead of BBC West. The Welsh ones are distorted and have to be deleted
  • 244 Answers
You could try a re-tune,use first time set up.
Posted on Apr 28, 2014
  • Jamie Andrew Knights Apr 28, 2014
  • 275 Answers
SOURCE: Recording
Does it record when you are simultaneously watching a program? if yes, then recording circuits are OK. It is definitely a problem of settings. Try doing it again step by step. And before you program for timer recording, make sure that the VCR clock is set for correct time.
Posted on Apr 07, 2007
Benimur
  • 6966 Answers
SOURCE: recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Posted on Nov 11, 2007
SOURCE: VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Posted on Feb 28, 2009
SOURCE: I HAVE A SONY DSR 45P DVCAM RECORDER. THE PROBLEM
Dear
you need to get your dsr 45 ,vtr repaired as the rec.inhbit cable is broken ....this usually occurs when the flat cable is broken.
Posted on Aug 15, 2009
  • 43 Answers
SOURCE: After recording a program using the Toshiba W522,
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Posted on Oct 22, 2009
I have a LOGIK 1TB freeviw Recorder and the following message keeps appearing on screen 'Can't schedule recording. There is already a timer at the same time on this channel.' Ther is not a timer recording...
Check that there is no recording set! Go to Menu and then Library settings and delete anything showing! This should clear the message showing again!
Dec 31, 2014 | Televison & Video
Vivitar iTwist 975DVR keeps stopping during recording. Have to turn off completely and turn back on again then continue recording until it stops again. Please help.
try with another memoy card, if the problem persist, ask for the manufacturer technical service to fix the problem as it is still warranty covered
Nov 29, 2014 | Vivitar Cameras
Dish changing channel to new recording while watching *pre-recorded* program
rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at thomas.faust@dishnetwork.com, and I can assist you further!
Tommy Faust
DISH Internet Response Team
Jan 23, 2012 | DISH Network 54 1 Ir Vip 622 722 Dvr...
Recording from a vhs cassette...
This dvd/vcr unit is having a problem with component failure. It is probably in the main power supply section, since the unit shuts down. This can happen in these products due to the qulaity of component use in the product runs. The components usually have 5% to 10% failure rate. Which is usually taken care of by the product warranty. Unfornately this is a common problem with big manufactuers and large production runs. You need to have the unit tested and serviced at a service center. The service center will have all the service information to repair you unit. The Magnavox Customer support telephone is 1-800-605-8453. Tell them the model number of you unit and about the problem with the unit shutting down during use. They will be able to tell how to your unit serviced. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
All of a sudden our DVR won't record a show that is set for a season series. We have to set everything for one time only record.This just started this week. We don't know what to do.
what you will need to do to correct this problem is delete the series recording. in your list (push list button) highlight the program you wish to delete, push select go to "rec. series" press select. and delete ALL push select... get "ok" message, select again. and reset receiver on front panel of receiver there is a door you can open, hit the red reset button and then setup your series record again by going into the guide and pressing record twice. this will fix the problem by deleting ALL of the series record and resetting, and resetting up series record
Mar 26, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Timer recording
If the internal clock is not correct, it probably wouldn't let you time record because it would record at the wrong time. Maybe there was a power surge and it caused it to clear the time?
Try setting the time through the menu and if you need a manual, call 1-800-SAMSUNG (if you haven't done that already).
Dec 05, 2008 | Samsung CXJ1364 13 in. TV/VCR Combo
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
Tried all advices but no solution...
cleaning with rubbing alcohol may have aggravated your problems - rubbing alcohol contains glycerin, which may tend to worsen the connections. to clean the connectors, use only _denatured_alcohol or electrical contact cleaner. the only connectors I have had to clean are the two leading to the video head.
Mar 29, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
