Question about Sewing Machines
Kenmore ultra stitch 8
Sewing machine turns on but needle doesn't move
  • Sewing Machines Master
  • 7,365 Answers
Having the machine checked to see if there is something wrong with the needle bar would be a good idea
Posted on May 06, 2014
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
SOURCE: How to thread a Kenmore Mini Ultra sewing machine
How to tread the sewing machine
Posted on Aug 23, 2011
How do I oil 8 stitch Kenmore sewing machine
LIft the top off the machine. There usually are two screws to loosen and the top cover will come off. There are oil ports by the moving parts. You will see small holes where a drop of oil should be put in. Then, wipe clean, close and tilt the machine back of show the bottom moving parts. Also, find the moving parts and a drop of oil on all ports to be oiled. Wipe clean and your machine should be oiled efficiently. Make sure the machine running parts are metal.
Oct 07, 2017 | Kenmore Sewing Machines
Stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
Nov 15, 2012 | Kenmore Sewing Machines
Kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
May 29, 2012 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
How do you position the needle/ with which lever or dial? location?
Your model doesn't have a specific needle position adjustment. But you could try this - set it to the shell stitch or lingerie stitch on the stitch selector but leave the stitch width setting on zero, this may move the needle to the left most position with any luck.
Other possibility is to put it in a step of the buttonhole sequence, but again leave stitch width on zero and see if this moves the needle bar to the right or left for you.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Kenmore 19233 computerized sewing machine
On my machine I find that my bottom and top free motion stitches are more uniform when I set my needle thread tension at 8 or 9. Also, you might want to use a top stitch needle.
Good luck,
SewReady
Nov 07, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
