After market scaler Faroudja in Sharp lcd
I have been shopping around for a 65" sharpe lcd and found two models. The base model is the lc-65D64u and the other is the lc_65D64upk the pk stands for "pro kit". What I have to told is the later has a Faroudja scaler installed which impoves the analog broadcasts. Its anywhere from $1,000 to $1,900. more versus the base model. They also throw in two 12' HMDI cables, a wall mount and two year warranty. Any thoughts.
  • 14 Answers
SOURCE: sharp lc 65d64u
What help?
Posted on Jul 25, 2008
  • 1779 Answers
SOURCE: which update is good for LC-65D64U
What are you looking to up-date on your sharp?
Posted on Oct 10, 2009
eagle338
  • 4889 Answers
SOURCE: Sharp 60" LCD Model LC-65D64U.
Does the blinking pause for a short time after blinking a certain number of times? Just checking whether the self-test diagnosis is able to detect the source of the problem.
Posted on Jan 06, 2011
budmrtn
  • 11361 Answers
SOURCE: Sharp LCD TV model LC-65D64U no sound no picture
Please check the power supply module main AC fuse, caps, and voltgaes.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sharp+LC65D64U+&limit=25
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 18, 2011
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Sharp, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
OK well what has happened i suspect, is that your set has been "Spiked" from a power disturbance, and this has damaged either the PSU, or an internal high voltage component, or both, and now, the Protection Circuitry in the SMPS unit, is "Sensing" a potential "Catastrophic fault", that may cause a fire an explosion or both, and accordingly the set MUST be shut down, so the protection circuitry does exactly that.
Your best bet, is to contact a local or head office of the TV's manufacturer, and ask them for a referral to an authorised servicing center. When contact is made with them, ask for a "Quote" for the repair, before allowing any repair work to be undertaken. This then at least will give you an idea as to costings and you can then make an informed decision as to repair or replace, as often these days i find in my shop anyway, many repairs can be very expensive, and often it would be better putting any monies that would have been spent on repair towards a NEW unit with a warranty.
Posted on Feb 12, 2011
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
Sharp Loud popping noise tv
The power supply regulator board should be replaced as card basis.
Aug 20, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
Need a base for LC-42D62U
http://www.partstore.com/Model/Sharp/Sharp/LC42D62U.aspx?SearchTerm=True
You will require the Stand, the screws for the Stand, and the Stand base assembly.
Mar 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jan 18, 2011 | Sharp LC65D64U 65 in. LCD TV
Which update is good for LC-65D64U
Oct 10, 2009 | Sharp LC65D64U 65 in. LCD TV
I am thinking about buying a used 65 sharp
I wouldn't recommend buying it unless it came with some type of warranty.
The most common thing you would be looking at for repairs if something goes wrong would be the Backlight Inverter Board or the Power Supply Board. It's what powers the big screen like that. Replacement board for one of them would be well over $200. And we're not talking about labor on top of that from the repair shop.
If you get it, try to get warranty with it. Add on extended warranty if possible.
Jun 04, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp 26"lcd tv stuck in standby,wont turn on
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. shkelzen65@gmail.com
Oct 12, 2007 | Sharp LC-65D90U 65 in. LCD Television
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
