Question about Lindeman Replacement Motor Brushes Ametek Pair Of Two
Horizon treadmill Model L5780T
Where do I purchase the brushes and how are they installed? It has a Johnson Integrated Drive motor Model JMO5-015.
Replaced incline motor on treadmill was stuck on incline 12 put new motor in and it went right back to incline 12 and stayed there what now? I spent 160 on this new motor and getting the same results
Hi There,
This person installed a new lift motor and had the same issue, so another new lift will do the same. What make/model of treadmill?
Lift commands come from the console to the lower board. Precor and some others use a Triac circuit to provide 120vAC for up or down, these parts can fail on the lower and cause this problem. Johnson Brands like Matrix, Vision, Horizon, Merit and others, use a relay set for up and down also commanded by the upper board.
I have seen upper boards cause this very problem. Contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 16, 2017 | Exercise & Fitness
My Horizon T91 threadmill is moving slower than normal. I checked both belts and there is no slippage.I opened the cover for control board, a red LED on in the lower part of the board.How can I fix?
Can be the motor or the motor control board faulty. You have to check the motor brush if it's OK the you should go for a new Motor control board.
if you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | Horizon Exercise & Fitness
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Push start and it moves 4" and stops but panel shows still moving. Well maintained, good belt with no binding. bad mother board?
Hi There, ... it sounds like a bad lower control board or MCB. Most control boards used by Johnson Health Tech, parent to Matrix, Horizon, Vision, Merit, AFG and others, have a small potentiometer on them for torque and/or speed adjust, that can be gently turned to the right, CW, to about 3/4 turn as the torque adjust widens the current sense threshhold slightly allowing a bit more current to the motor. This adjustment should only be done with the unit off unless you are used to working with treadmills. Fitness Remedy in Sun Prairie Wis., repairs most fitness electronics.
Oct 11, 2015 | Horizon DT680 Motor Control Board
What is the main cause for motor failure in a CT7.1 tradmill
The CT-7.1 is the exact same treadmill as the Horizon T-202.
Treadmills use brushed DC motors. It is possible that the brushes are worn out. You may be able to purchase new brushes on-line. You can source them by searching for replacement parts for either of the above two makes and models.
It is also possible that some circuitry on the control board has been damaged or even something as simple as a sensor switch has failed.
Mar 16, 2015 | Exercise & Fitness
Where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
Jan 06, 2015 | Horizon Exercise & Fitness
Fix magnets on Johnson integrated drivers JM05-015
1_21_2013_5_49_11_pm.giftest for open or faulty,clean it, and tight the connector very well. God bless you
Jan 20, 2013 | Horizon Exercise & Fitness
Where will I buy a gearworks model jm05-002 treadmill motor
I doubt you need a new motor if you have not checked the brushes. Hard to put the clips back in place though. I am having trouble doing this. You may have a Horizon treadmill. If so you can down load info from there web site. Although USA web site. UK bit stuck on that.
Oct 05, 2012 | Exercise & Fitness
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Lindeman Replacement Motor Brushes Ametek Pair Of Two Logo
54 people viewed this question
Top Lindeman Home Experts
Donni Steen
Tom Chichester
Are you a Lindeman Home Expert? Answer questions, earn points and help others
