Question about Dell Computers & Internet
Cd n dvd drives not recognised in My Computer
DVD drive not recognised in My Computer and CD drive wont read my disc
    New Friend:
    Problem Solver:
  • 19 Answers
If one drive has resently been installed on the back of the drive there is a jumper with 3 choices of c/s S and M if the jumper is set to cs changer one drive to M for master and change the other drive to S for slave and reboot. If it still wont show drives try reversing the jumpers and reboot. If still not working change your cable to the motherboard.
Posted on Nov 23, 2014
4 Suggested Answers
SOURCE: issue with cd/dvd drive
Did you try cleaning the drive? Maybe uninstall the driver and then reinstall it.
Posted on Feb 13, 2008
  • 52 Answers
SOURCE: dvd/cd drive problems
Take the drive out and carefully take off the top. The lase shines through a very small glass cover that looks like a small light bulb. Clean the very fine layer of dust off of this glass "eye" and this MIGHT fix your problem. I have seen this happen dozens, if not hundreds of times. Keever
Posted on Mar 06, 2008
  • 47 Answers
SOURCE: My NEC DVD + RW ND-1100A will not read pre-
This is likely due to media that was released after your drive was manufactured or not included in their firmware. Often updating the firmware on the drive can overcome this issue. you can download the firmware update here:
http://support.necam.com/optical/downloads/flashfirmware/
Warning: Read ALL of the directions and follow them carefully. Failure to do so (for example powering the system down during the update) can result in a non-functional drive.
That said, it is typically fairly painless. If you are not sure you can do it, you should contact NEC support for them to walk you though the process or even send the drive to them.
Good Luck,
-Tor
Posted on Nov 20, 2009
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
When attempting to copy blu ray disc message reads disc not detected.(emachine e525)
Although the same shape and size, Blue Ray disks are a completely different format to DVD's and CD's. You drive won't recognise them
You'll need to get a Blue ray RW drive, and it doesn't stop there. Because there a great deal more information on a blueray disk, you'll need several dvd disks to copy the info to a DVD.
Bluerays hold about 25Gb of data, DVD's hold 4.7 GB and CD's hold 700Mb data.
Jul 10, 2010 | E-Machines emachines (emachinees) CD-ROM...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
Computer DVD/CD Drive does not recognise any discs
The most likely cause is a faulty DVD drive. Replacing the DVD drive is fairly simple.
You can buy a new one online for around $25 including shipping. If you need help finding a drive or installing a drive, I can help with that. Just let me know.
Jan 08, 2009 | NEC Computers & Internet
My Lite-On combo sohc-5236v does not read CD but it reads DVD.
The reason for this is most likely Copyright protection. If this is the case, it will read DVDs as it is only a DVD-ROM, but what happens in the case of CDs, is that they recognise the drive as a Burner, and the Copyright that is embedded into the CD wont let the drive read it. This also happens with DVDs in some DVD burners.
The way to test this, is by getting a CD-RW disc that has music or files on it, put it in the drive, and see if it reads it. If it doesn't, then you may have a fault with the drive, but if it does read the CD-RW, then the only way round it that I know of, is to buy a CD-ROM drive and use both drives.
Dec 05, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Samsung cdrw/dvd sm-308b
your drive have a problem in CD unit - the drivers with CD and DVD have 4 units (CD Read, CD Burn, DVD Read, DVD Burn) one fail not fail all, your drive can't read but burn a cd, or inverse.
buy a new drive for solve this problem.
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
Alun Cox
