Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes do not turn worked , fine last time i used it a month ago.
  • 54 Answers
The brushes are run by vaccum. Take the brush out and there is a passage way in there that could be blocked. If I rememer correctly there is a screen in there. If that dont help then there is a spring hooked to a lever underneath so when you lay the back down it engages caccum to the rollers. It could be that this is stuck and not moving. Try moving it by hand with the scrubber running.
Posted on Jun 20, 2009
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
My vacuum was great when I first got it a few months ago, now it won't pick anything up off of the floor. The removable hose works fine, but the main vacuum isn't working at all. I checked the hoses for...
you could have a clog at the begining of the suction port above brush roll check that and make sure the brush roll is spinning if not it wont pick up anything
Feb 16, 2011 | Eureka 3276AZ Pet Lover Bagless Upright...
Hoover WindTunnel, month-old belt, now too large to turn brush
I suspect you have been bitten by the Chinese bug.
A very large percentage of replacement parts for all manner of appliances and vehicles are now being conterfeited in China who we should know by now has no respect for the intellectual property of others and a flood of low-quality stuff is being made as 'knock-offs' since they are generally easy to fabricate with fairly primitive means. Our eldest son just returned a supposedly 'new' steering pump for his (US) car but this one at least had China as the origin shown on the package.
Make sure though that the brush roller turns freely and isn't being impeded by trapped thread in the bearings.
Mar 21, 2009 | Hoover U6630-900 WindTunnel Bagless...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
No suction
If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage.
May 30, 2008 | Riccar 8955 Upright Vacuum
Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Mar 20, 2008 | Vacuums
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
245 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
