Question about Kyocera Office Equipment & Supplies
MY PRINTER SAYS PAPER JAM BUT I CHECK NO PAPER JAM WHAT DO I DO
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Find the paper jam xD haha check the sensors make sure none are broken or stuck and again theres always the possibility theres a torn piece of paper in it
Posted on Aug 11, 2014
dodgecharger
  • 254 Answers
SOURCE: What paper jam?
Does the printer even try to pick a piece of paper from the supply tray? If not, then it would appear that a sensor somewhere in the paper path is bad, either mechanically or electronically. Often, these sensors have a lever which touches the paper. If by chance the lever is broken or stuck it won't give a correct message to the logic circuit. If by chance the sensor is electronically defective, it would still give a bad message to the logic, and it would need to be replaced. Logic circuitry could be bad, in which case, replace the printer. With the lowcost printer/all-in-one units these days, it seems fixya has a continual flow of inquiries. Maybe this will give you some help.
Posted on Aug 09, 2007
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
altaf702
  • 28 Answers
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
Posted on Feb 28, 2009
SOURCE: printer keeps saying paper jam
we had the same problem at the college where i work. the print queue had somehow clogged up to such a point where the printer was doing this. the constant paper jam light & the printer taking paper when printing test sheets etc. we solved it by deleting the printer & then re-installing the drivers. may not work for everyone, but it certainly worked for us.
Posted on Mar 11, 2009
NitrusInc
  • 326 Answers
SOURCE: I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Posted on Apr 13, 2009
Paper jam error
check your printer if there is anything paper stuck
clean it maybe there is dirt that causing paper jam.
and if the same problem. plss check the paper jam "sensor"
Apr 24, 2014 | Epson DFX-9000 Matrix Printer
Paper Jam.
unplugg power cable from pritner. press adn hold 6 and # key on printer at same time. while holding them down plug it back in at same time. let pritner alligne afdter that. then it shud work fine
Dec 15, 2009 | HP Officejet 6500 Wireless All-in-One...
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Problem
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
108 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
