Question about Toshiba E-Studio 2040c Copier
I got an Error Code F106 (Point and Print partition damage). Screen is frozen. Any troubleshooting suggestions?
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Toshiba studio 257 how to fix error code F106
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Jun 09, 2016
Jun 09, 2016 | Toshiba Office Equipment & Supplies
Toshiba e206l error code F106 sub code 5
this is either a hard drive error in which case you need to replace and reload firmware Or this is a communication failure in which case checking all the boards and connectors may fix it or you have a bad board.
Jul 09, 2015 | Toshiba Office Equipment & Supplies
HP Z6100 error code 79:04
79.04 is a system error like ablue screen in windows. The troubleshooting process is very complex. Your best first step would be to disconnect any data cables and restart. If the machine comes to ready then it may be that you are sending data with either a corrupted print job or the wrong driver. If it errors even with the data cable disconnected then you will probably need to reset the eeprom. Make sure that the formatter is seated properly and all components on the formatter are seated properly.
Nov 08, 2014 | HP Designjet Z6100 InkJet Printer
Hp printer 2515 allocating an error code - 00000000 reason being for this error code?
Based on the descritpion, it appears that you are getting an error message "error page 00000000" before normal print job. I will be happy to fix this issue.
1) What do you mean by "prints page with error 00000000"?
2) Have you made any changes on the computer prior to this issue?
I would suggest you to follow the steps to run the troubleshooter and check if the issue persists.
Open the Printer troubleshooter
CBR Tech Solutions or http://www.cbrtechsolutions.com
Aug 12, 2013 | Office Equipment & Supplies
HELP!
You have what is called the "blue screen of death", what this is caused by is a catastrophic failure of the operating system software in the computer. When you bought the computer you were either provided with a set of recovery disks to reload the operating system or prompted to make them from files in the system already. You must reload the operating system to correct this, there is just no other easy way around this. If you con;t have the recovery disk set contact the parts dept for the maker of the computer to order them, they are fairly cheap.
Feb 13, 2012 | Office Equipment & Supplies
There is no recovery partition.
I can only be these causes.
1: hdd bad.
2: it's telling you the truth, the restore partition is corrupted,
takes way more than simple file names, there.
3: someone used microsoft disks or others, an attempted to install other OS, and wreck this partition structures and files.
the cure is same, HP media kit. (posted 100000 time at hp,)
https://support.hp.com/us-en/document/bph07143
May 19, 2017 | HEWLETT-PACKARD G72250US Laptop
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Toshiba E-Studio 2040c Copier Logo
636 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
