Question about Teeter Hang Ups Exercise & Fitness
My teeter will not lock into place when upside down?
When go upside down my teeter will not lock into place and it use to...
Uniden 650 dashcam. I had to record with the camera upside down not enough space for the succion cup. The view of the recording is upside down. How can I flip the view or what would be the procedure?
If the camera is upside down, then ipso facto the recording will also be upside down. either fabricate some other form of attachment for it (maybe place it at a different place on the windscreen), or use software on your computer to rotate the resultant footage by 180 degrees. Not rocket science.
Dec 23, 2017 | The Video Cameras
Can this dryer be used upside down
Dryer can not be installed up side down motor and pulley will not work properly running up side down can't understand why would you need too send pictures very interesting
Feb 27, 2015 | Haier GDZ5-1 Electric Dryer
Someone (newphew-in-law) installed a deadbolt (Schlage) for me and now I see it is upside down. The writing is upside down, and it locks by turning to left and unlocks by turning to right. This is an...
There is no problem with the lock being up side down ... tell your nephew-in-law thanks for his fine job.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Garden
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
Stanley sharp shooter tr110 staple gun. will not staple after loading. got ideas?
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Sep 27, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
Remove stand from samsung ex2220
The snap lock you speak of has a small lip on it that lets it lock in place. Simply find this snap and gently press it back to unlock. On mine I have to turn it upside down to do this.
Apr 04, 2010 | Computers & Internet
How do I load this Stanley Staple Shooter Light Duty?
This doesn't load like normal staple guns. Go to the end of the stapler and pull out the locking device with the spring on it. Then turn the staple gun upside down so you're looking at the bottom of the gun. See, there is now a little channel exposed. Drop the staples in this little channel with the points of the staples pointing towards you. Keep the staple gun upside down and reinsert the locking device which will compress the staples. PRESTO! Ready to use.
Aug 26, 2009 | Powerfast Stanley TR110 Light-Duty Staple...
Planetary ring
ok im going to take a shot at this its been a while since ive been in a school kitchen
with the planetary ring its supposed to be tapped in make a jig by getting a 2x6 board and 2 2x4s they dont have to be long screw the boards together with the 2 2x4 standing 4 inch up across from each other about the size of the blender head
the wood is to support mixer while on its head and to keep from teetering around
put down down a piece of foam
put the mixer on its head upside down
now you have to find an old plastic sturdy made cup the size of the ring its gotta be able to take a beating (the cup)
but not a hard beating this will help in seating the panetary ring
now get another piece of foam
glue to top of cup let dry then trim around the cup evenly out side and on the inside leave a little foam over the inside edge
place ring on planetary drive where it goes put cup over ring make sure the cup matches size of ring
now get a wood rubber or small pin hammer and tap lightly on the cup till the ring sits itself back into position this is the safest way to place the ring
use a little appliance greese on inside ring lightly to help ease into place
now if any part of the ring is bent i dont recommend placing of old ring i would suggest buying a new ring for mixer
Jun 11, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
My monitor is upside down
my phillips monitor 170s has the brightness screen and the OSD controls locked/unlock how do I fix this
Jun 03, 2008 | Philips 170S4FG 17" LCD Monitor
Exercise & Fitness Logo
62 people viewed this question
Top Teeter Hang Ups Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Teeter Hang Ups Exercise and Fitnes Expert? Answer questions, earn points and help others
