Question about Vehicle Parts & Accessories
Key remote will open boot but will not lock and open doors
    Habit-Forming:
    New Friend:
  • 186 Answers
First I assume you still have the installation guide as far a what color wire is associated for your door locks. Next google "your car make and year and the proper wire connections for alarm system". You should find several sites that will tell you exactly where to find the colored/stripped location of said wires. Find the one that activates/de-activates your door locks. Now in some situations you need to install a "relay", if so don't let it scare you you cause a relay is nothing more than electrically operated switch.
Posted on Apr 28, 2014
My key opens the doors to my peugeot 407 but will not open the boot
The boot and glovebox have a different key, so your valuables can be kept away from servicemen,central locking remote will open boot with doors
Jul 14, 2014 | 2007 Peugeot 407 2.0
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
Central locking will not work from key but will unlock if manually lock car
The automatic door actuator must be responsible or open all door including the boot and close them one after the other firmly,see if it work and if it does not work your door actuator need replace.
Feb 22, 2014 | Cars & Trucks
Remote car door opener
This sounds like a door lock fault. Will need a replacement lock, or there may be a broken wire in the door to pillar boot.
Jan 17, 2014 | 2008 Volkswagen Golf 1.9
Driver door wont lock/unlock with key or remote
Year make and model. You may have a inoperative door lock actuator.
Jun 23, 2012 | Seat Ibiza Cars & Trucks
Mercedes c class 2001 elegance, key fob not working everytime its pressed. I have had the batteries checked and they are still working fine, any advice as to what is causing this?
Most likely needs to be re matched to the car.
Two bits of info off the net for you
C CLASS (1993-1997), E CLASS (1995-1997), SLK (1996-)
Procedure
1. Point the remote control at the receiver - this should be located in the driver's door handle or next to the boot lock button.
2. Press the lock/unlock button.
3. Within 30 seconds manually lock or unlock the vehicle using the passenger's door lock or the boot lock.
Alternative method
Procedure
3. Within 30 seconds, switch the ignition ON.
Alternative method
Procedure
3. Within 30 seconds, turn the ignition switch to position II.
and
1. Place key in ignition lock and turn to position 2 [all ignition lights on]
2: Turn key to off position and remove from ignition.
3. Within 10 seconds:
3a: press the Close [Lock] button and hold it down
3b: while the Close button is still depressed simultaneously press the Open [Unlock] button. Press and release the Open button 5 times [still holding the Close button down]
3c: Release both the Close and the Open buttons at the same time, and immediately push any of the two Open buttons once [i.e. either the Open doors or the Open Tailgate]
This information is for the resetting of a previously synchronised key to match the security system after batteries have been removed or replaced. This information does not work with new keys which it seems must be taken to a person with a key synchronisation device [or a super-ripoff-expensive MB dealer]
hope this helps
Aug 13, 2011 | 2002 Jaguar X-Type
I just bought a 1996 jeep grand cherokee larado, I locked the doo while inside with electric lock switch on door. I then opened the door with the handle. the alarm went off which I did not know it had. I...
lock with key,electric door lock button,or remote and alarm will set. to disarm you have to use the key or remote to open it.the reason it woulnt disarm from drivers door is either the door lock cylinder switch is broken or the wire to it in the rubber boot that connects the door and the body is broken.
the remotes are cheap and programing is easy,procedure in owners manuel something like lock drive door with elkect. lock switch with door open then push and hold unlock untill doors unlock then turn key off.you may have to fix that drive door lock cyl.switch first though mabee not dont know for sure
Mar 22, 2010 | 1996 Jeep Grand Cherokee
Remote central locking
the buttons in the key are worn, you need a new key.
Aug 04, 2009 | 1996 BMW 318
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Vehicle Parts & Accessories Logo
16 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
