Question about Radio Communications
When i push the ptt button on my audiovox radio it shutsthe radio off
  • Radio Commun... Master
  • 1,654 Answers
Commonly this can be a sign of a low or bad battery. It takes more power to transmit than to receive, so when you press the PTT button on a radio with a poorly charged or bad battery it will often fail. The same radio will run in standby mode (receive only) for long periods of time.
So before looking for a more complex problem, you might try swapping your battery with another radio's known good battery to see if it solves the problem.
Best regards.
Posted on Apr 22, 2014
Neto
  • 123 Answers
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Posted on Feb 14, 2008
SOURCE: They just don't seem to work!
I had the same problem, I solved it my holding down the PTT button on one and the scan option on the other. It seems that the channel indications are faulty and and Channel 1 on one matches with Channel 15 on the other and so on. But once this was sorted the units work fine.
Posted on Apr 27, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola AXU4100 2-Way Radio Problem
Have the radio reprogrammed at your local Motorola shop.
Posted on Jun 26, 2008
vrc_tech
  • 109 Answers
SOURCE: Audiovox FR530
follow instructions on page 13 of your manual "using monitor button" place receiving radio in monitor and key up other radio. It is better if you have someone help. have another person take the radio to another room away from you to complete test. sometimes if the radios are two close too each other they will cancel each other out.
Posted on Aug 19, 2008
SOURCE: TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Posted on May 30, 2009
Will not Transmit.Display Indicates "release mic button" and radio buzzes
The PTT button is probably stuck and your radio is already transmitting.
PTT = Push To Talk
Sep 09, 2014 | Boating
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
Shuts off immediatley after pushing PTT button
sounds like your batteries are shot and not able to supply enough power for transmit
Jan 10, 2014 | Motorola Walkie Talkie 2-Way Radio
AXU4100 resets every time I push the ptt button
The battery is dud and the voltage drops when transmitting
Nov 26, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
Sqeal when talk button is pushed
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
Apr 21, 2009 | Audiovox 2-Way 14 channel FRS Family Radio...
I got these walkie talkies audiovox
try to work the ptt switch on and off rapidly a few times see if that works.
Apr 11, 2009 | Audiovox GMRS602PK 6-MILE GMRS 2-WAY RADIO...
One radio not sending
hold the the ptt button for a minute in both handsets
Mar 07, 2009 | Motorola Talkabout FR50 (14 Channels)...
Simple HOW-TO
If your radios are set identical to one another, you simple need to press the push-to-talk button (PTT) and hold it in while talking. Let go when you are not talking, in order for the other person to be able to press their PTT and talk back to you. The monitor button is only for checking to see if other users are talking on your same frequency, and if so, you are to be polite and not talk over the top of them. (So the rules say.)
Oct 09, 2008 | Audiovox Radio Communications
Audiovox FR530
Aug 18, 2008 | Audiovox FR530 (14 Channels) 2-Way Radio
One way comm only
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
