Question about Chauvet Arena Hazer 2 Haze Fog Machine + Haze Fog Juice
Chauvet arena hazer 2 - Chauvet Arena Hazer 2 Haze Fog Machine + Haze Fog Juice
2 Suggested Answers
  • 5603 Answers
SOURCE: Looking for a heating coil
Use high air pressure after soaking the element. This means the pressure from an air compressor not the little canned air things. You might do this while element is hot... use EYE protection while doing it!
Posted on Sep 08, 2011
How to fix chauvet CH460LS
*BUMP* I, too, have a dead channel on my Chauvet CH-460LS Controller-Dimmer.
Jun 05, 2014 | Chauvet Followspot 400g with Stand
Looking for a heating coil assembly for the Chauvet Arena Hazer 2. The unit I have has a plugged element, and I can't seem to get the clog cleared. Just need to replace the whole assembly.
Sep 07, 2011 | Chauvet Arena Hazer 2 Haze Fog Machine...
I have 2 chauvet jsix's, both have defective sound activation out of the box new, whats the deal here? is there an easy fix?
Some of these require a fairly high sound level and mostly at low frequencies. Try clapping near the unit... If that doesn't trigger it not much will.
Jun 01, 2011 | Chauvet Jsix Led Dj Dual Moonflower Effect...
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
I have numerous Chauvet 200b LED lighting fixtures. The problem I am having is: the "blue" LED"s on most every fixture are starting to go out. All the other colors are fine (it's just the...
Before jumping to conclusions, one should do some testing. It is posssible that you are having a DMX data error. If your lines are long, please review the need for a termination resistor at the far end of a DMX chain. The reflections of the data pulses can confuse or cause errors. Test a unit up close to your controller so the cable is short. If that magically works, install a terminating resistor.
Beyond this, electronic testing needs to be done. I did find in a Chauvet LX5 a bad solder joint at a connector that brings the power for, in my case, the green LED's. There will be surface mounted resistors on the back of the board that limit the current to groups of LED's.
If the whole fixture loses the blue at once, either suspect a DMX error or the driver in the fixture.
Mar 02, 2011 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
Just got a Chauvet Trident and plugged it in and the moter tunrs left then right , then stops ? The LED's blink 1 time then that is it ?
The left right motion is when the motor calibrates its position. The unit is then waiting for input... try generating a loud noise... if the audio gain is up and it is configured for manual rather than DMX it should start.
Dec 24, 2010 | Chauvet Brand New Chauvet Trident Dmx-512...
Have 2 Chauvet Intimidator Spots. 1 no longer projects light and the bulb is not the issue. It powers up, goes thur its start up routine but will not light the bulb
This unit got a 24volt lamps that came from a transformer. Usually the ceramic contact of the lamp get damaged and corroded after some time and can be replace. You should test at the same time that the voltage is allright with a multimeter. Most sound shop keep such ceramic in stock because its always broken....
Aug 10, 2009 | Chauvet Followspot 400g with Stand
DMX-55 Chauvet
Try joining www.djforums.com and posting there to see if there are any Spanish speaking members who can help you.
May 22, 2009 | Chauvet Dmx 55 Dmx Controller
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
Chauvet Arena Hazer 2 Haze Fog Machine + Haze Fog Juice Logo
19 people viewed this question
Top Chauvet Music Experts
Vito Vacirca Jr.
Are you a Chauvet Music Expert? Answer questions, earn points and help others
