Question about Danby DPAC8020 Air Conditioner
I have an everstar mpk-10cr and it leaks water out
I have an everstar mpk-10cr portable A/C and it leaks water out of a drain at the middle bottom of unit. I do not know if a cap is suppose to be installed there or not. I plugged it up but water did not go into the normal receptacle. Took out plug and water gushed out.
  • jalford2 Jun 21, 2009
    My everstar mpk-10cr portable A/C leaks water out of the very bottom hose on the back of the unit. I do not know if there is a cap missing or not. I taped up the end of the hose since I did not have a cap to see if the water would go to the receptacle on the side like it is suppose to. This recptacle can be pulled out to empty, if it fills up it will cut off the condenser and not produce any more water. Ideas???????
    Problem Solver:
  • 11 Answers
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Posted on Jun 20, 2009
  •  xxxx
    xxxx Jun 21, 2009
    jalford2Forget everything said up to this point. This sounds like an air conditioner and not and an evaporative cooler. If that is true then then you have water condensing on the coils and that has to be drained off or the collection bucket emptied regularly. If you are where it is humid that could be quite often. The drain you speak of is so you can add a drain hose to siphon off the water and not have to empty the bucket. There is probably a safety switch that cuts off the compressor when the bucket gets too full.
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Water leaking
Water can fall off of coil prematurely, before it reaches the drain pan, sometimes due to debris on the coil surface, airflow turbulence in the return air box, and in some instances I've never resolved until the machine was replaced. The drain pan could be cracked or have blocked channels that allow water to drain from the rear to the front. It could also have ice on it/freezing up. Some will developed a thin sheet of ice and drip water. The drain line may be stopped up or broken/loose fitting. Some coils have a laminate on the aluminum fins that can deteriorate. Hope this gives you something to check!
Jun 13, 2015 | Everstar Portable Air Conditioner MPK-10CR
My Everstar portable air conditioner model# MPK-10CR-1 will not drain into the bucket that comes with it. It is draining into the tray at the bottom of the unit then the unit turns off when the tray is...
Simple I believe...just run a weed eater line up the whole in the back where you have the clear tube. You can take the little back door off the power cord area to see inside where the water drips into the little tray before it goes down the hose tube. Water debris sometimes blocks the water from draining properely. The weedeateer line will clear the blockage and it will begin flowing again.
Jun 27, 2010 | Heating & Cooling
My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Just got one of these used, and also got the P1 error. Took the case off (which just involved a lot of Phillips head screwdriver turning), and found a sensor switch just to the left of the drain box inside the case. If I press on the sensor switch, the P1 error goes away, but then I get a blinking dot on the LCD display. Pressed the power button after that (while still holding the sensor switch) and it started working again. It looks like it was super-glued either originally or by a previous owner. Just needed to be re-positioned towards the top left corner where the drain pan sits. Just be careful when removing the case to not disconnect any of the wires going to the LCD display.
Sep 21, 2009 | Danby DPAC8020 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
May 07, 2009 | Heating & Cooling
Danby DPAC8020 Air Conditioner Logo
3,760 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
