Question about Teeter Hang Ups EP 960 Inversion Table
Mine will not lock into place when upside down?
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
Electrolux EWF 1090 not starting or even locking door when start/pause button pressed. All buttons work and light up.
Bad idea turning machine upside down - water from the soap drawer / sump hose / filter can run into several electronics panels. Sounds like you may have problems with this - and a repair won't be cheap. Door usually locks if nothing else - yours doesn't . If machine is 6 years old or so - get estimate for repair, but look at new machine also.
Nov 01, 2017 | Electrolux Washing Machines
Someone (newphew-in-law) installed a deadbolt (Schlage) for me and now I see it is upside down. The writing is upside down, and it locks by turning to left and unlocks by turning to right. This is an...
There is no problem with the lock being up side down ... tell your nephew-in-law thanks for his fine job.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Garden
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
I don't have the instructions to my graco pack and play and I can flod it up to put it away. Someone help!
I don't know if this one works like my Century Fold-n-Go or not. If it does be sure that you have placed the pack n play upside down then try to push on release buttons that are in the middle of each of the sides.
I think its a safety feature that keeps kids from accidentally releasing it when they are inside. Mine will only close if it is upside down.
Hope that helps :)
Dec 22, 2010 | Graco Pack 'n Play
Stanley sharp shooter tr110 staple gun. will not staple after loading. got ideas?
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Sep 27, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
Remove stand from samsung ex2220
The snap lock you speak of has a small lip on it that lets it lock in place. Simply find this snap and gently press it back to unlock. On mine I have to turn it upside down to do this.
Apr 04, 2010 | Computers & Internet
How do I load this Stanley Staple Shooter Light Duty?
This doesn't load like normal staple guns. Go to the end of the stapler and pull out the locking device with the spring on it. Then turn the staple gun upside down so you're looking at the bottom of the gun. See, there is now a little channel exposed. Drop the staples in this little channel with the points of the staples pointing towards you. Keep the staple gun upside down and reinsert the locking device which will compress the staples. PRESTO! Ready to use.
Aug 26, 2009 | Powerfast Stanley TR110 Light-Duty Staple...
Repair Casio Exilim EX-S500 Battery Lock
Hi you can go back to the casio repair centre to get it done. Mine actually broke off and it was repaired within half an hour :)
Mar 16, 2008 | Casio Exilim EX-S500 Digital Camera
Teeter Hang Ups EP 960 Inversion Table Logo
64 people viewed this question
Top Teeter Hang Ups Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Teeter Hang Ups Exercise and Fitnes Expert? Answer questions, earn points and help others
