Question about Rangemaster Kitchen Ranges
Need manual for rangemaster 110
Operating manual
  • Rangemaster Master
  • 3,382 Answers
Go to this web site and download the manual: http://dl.owneriq.net/d/d3bd6a41-5648-4fac-9912-68ff932471ba.pdf
Posted on May 01, 2014
grandadfixer
  • 99 Answers
SOURCE: Rangemaster 110 Fan runnig slowly
Needs new fam assembly.We can supply parts if req.woolleysltd@yahoo.co.uk
Posted on Nov 05, 2008
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
SOURCE: What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
Posted on Nov 14, 2009
SOURCE: Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Posted on Feb 07, 2010
EllaWatson25
  • 725 Answers
SOURCE: rangemaster 110 oven element replacement
We can help you with this repair!
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
FLAME BURNING WITH WHITE FLAME
You need to introduce more air to the flame. There is an adjustment just before the burner tube on the pipe from the knobs. My advice is to get a gas engineer to do it as he will also adjust the low setting for the flame which is also likely to be out of adjustment. It will only take him 30 to 40 minutes.
Mar 22, 2016 | Rangemaster Classic 110 Kitchen Range
Need to convert my rangemaster from ng to lpg but manufacturer is saying our model is unconvertible - help
Hi Helen.
Especially if you have a rig that calls itself Dual Fuel, it would seem that you should be able to convert. I looked up a manual for the Classic 110
http://www.rangemaster.co.uk/media/868812/toledo-lidded-110-dual-fuel.pdf Page 23 of the PDF (19 of the manual pages) specifically talks about there being conversion kits to swtich to different fuels. It also underscores that this should only be done by a certified gas engineer.
That said, my experience from shopping appliances for our house remodel several years back was that some sales people just stared blankly when we asked about running stoves on propane (we're a bit out in the sticks, no Natural gas hookups). Others would look at the same equipment and say 'oh, you need the converter fixture, which was more or less a flow restrictor to keep the energy content about the same as for the NG (propane is a bit higher energy content than NG).
In short, you should be able to convert between fuels, and the manual from the company itself says so.
Good Luck!
D
Dec 08, 2015 | Rangemaster Classic 110 (Dual Fuel) Dual...
How do I take the door of a rangemaster apart?
Hi Tim,
I suppose it is the cooker of the photo, a Rangemaster Classic.
These doors open on the side.
There are 4 screws who fix them.
Unscrew them and you can take the door apartThe link is for the user manual. On page 18, fig 6.3 and 6.4, you find more information.
Have a nice weekend, Dik
Jul 02, 2015 | Rangemaster 110 (Gas) Kitchen Range
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a rangemaster 110 LPG Hob and double oven cooker. I will be moving to a mains gas area and would like to convert it to natural gas. Is this possible?
Hi, a complete shot in the dark as its a while since you posted - we have a mains gas rangemaster 110 and need an LPG one, do you still need to change or have you sorted it now? Cheers
Dec 04, 2009 | Rangemaster 110 (Gas) Kitchen Range
How do i bypass the clock on my rangemaster 110 cooker
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
Nov 11, 2009 | Rangemaster 110 (Gas) Kitchen Range
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
62 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
