Question about OKI MICROLINE® ML390 Matrix Printer
Oki data 391 prints a blank page after each use how can i fix this
SOURCE: waiting your help
You probably need a new drum (not included with the toner cartridge). When the drum assembly is used up the machine will print one page and then stop. If you open the cover and close you will get a second page. The only way to truely know if the drum is used up is to connect to the printer via a parallel connection and then run a program that is on the driver CD. Then you will get a readout of the drum life. Details are on the Oki web page. This was exactly the problem we encountered with our B4250. I believe you will also have a flashing indicator light on the top panel that doesn't seem to make sense. It will clear along with the problem when you change the drum. Good Luck!
Posted on Oct 03, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Yellow Lines on every print
If the optics are clean (use lint free cloth on 4 rows of black thingys underside of lid)
Then it sounds like the yellow drum needs to be replaced, when printing in word I'm guessing that you have it set to B/W prints hence no colour is engaged, no lines
Posted on Oct 17, 2007
flopez
  • 161 Answers
SOURCE: oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Posted on Nov 07, 2008
SOURCE: microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Posted on Apr 07, 2009
  • 13 Answers
SOURCE: Oki data c5200. When printing
Could be 2 differents problems.
1st you can clean the leds.
2nd you can change the drum of the color problem,
Posted on Sep 21, 2010
My oki b 4600 print one page then get jamed paper how i can fix this problem please help me
Age and wear can make a roller shiny and so, slippery, and so cause bad paper feeding
To fix a shiny roller, rub it down with a coarse nail file which yes, will often involve stripping the machine, at least partly.
Consider also, how much would a new machine cost, and take into account that such a thing would come with new ink
Oct 01, 2016 | Oki Data Americas, Inc. B4600 LED Printer...
How to get oki microline 391 turbo to work with windows 2003 server?
use the HP laserjet 4 or 4000 print driver. this is the most basic print driver and has played nicely with the older printers
Jun 02, 2014 | OKI MICROLINE Office Equipment & Supplies
Printing blank pages and pages with symbols on them
There are two main caused of blank printouts in inkjet printers:
Low ink level
Clogged nozzle of the ink cartridge
Refer to this article:
Blank Page while printing
Dec 18, 2012 | Oki Electric Industry C5900N Led Printer
My OKidata ML 390/391 is printing an extra page after it prints the data page.
This vintage printer typically has a set up or dip switch setting that forces a page at the end of each print-out to allow positioning
Sep 14, 2011 | OKI MICROLINE® ML390 Matrix Printer
Error code 391 paper jam - no paper jam though. Open front cover and close and that resets machine but when you try to print error code 391 again!
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
May 04, 2011 | Oki Electric Industry C6150N Laser Printer
Microline 391 okidata continous feed leaves a page of space
Thanks
Apr 05, 2009 | OKI MICROLINE 390 Turbo Matrix Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page comes up blank !!!
check your rribbon.
also cjeck your head.
try to tast page from printer properties.
also try to print from dos .
check your printer datga cable.change it
OKI MICROLINE® ML390 Matrix Printer Logo
37 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
