Question about Boating
Evinrude junior water pump replacement - Boating
3 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: 1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Posted on Apr 14, 2009
  • 106 Answers
SOURCE: how do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Posted on Aug 19, 2012
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
How to replace water pump in a evinrude 25hp 1985
split lower unit at bolts, disconnect shift rod then you will find the water pump, repair all parts needed and reinstall lower unit .
Jun 11, 2014 | Boating
Need to see the assembly differences on a evinrude 35 hp (1978) long shaft and short shaft. I am changing my long shaft to a short shaft and there is a tube that I don't know the purpose of.
Try going to: http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
There you can search out all differences. You will need year, make and model # of your engine.
The tube is probably a water pump alignment tube to insure the water pump tube goes into the water pump since its not visible during installation.
Oct 06, 2013 | Boating
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Aug 17, 2012 | Boating
Evinrude 15HP Outboard - Vent Holes
have a problem , check impeller pump
Sep 07, 2017 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
Evinrude 7.5hp pumps water but gets hot and turns to steam if thermostat were is it ive looked and mine has not got one thank you
would guess that the water pump impeller needs replaced . weak ones will push some water but not enough
Jun 27, 2010 | Boating
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Mar 19, 2009 | Boating
Boating Logo
48 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
