Question about Canon PIXMA MP160 All-In-One InkJet Printer
My MP160 Printer is plagued with problem Service Error 5010. Neither I can print nor scan. Please help me to fix the problem.
    Problem Solver:
  • 20 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi20
Posted on Sep 05, 2009
  • 55 Answers
The 5010 error relates to the drivers. Download the latest driver for your operating system and model of printer. Uninstall any previous attempts to install the printer, unplug the printer completely, restart your computer. Install the drivers using the file you downloaded from canon, do not attach the printer to the computer, or power on until you are told to do so. If you are still having trouble please post back.
Posted on Jun 20, 2009
Sir gud evening may problem is may canon print mp160 allway servise error 5010 please help to fix the problem thanks
hello there
Error 5010 is caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
http://dl3.paretologic.com/webair/dl3/downloads/pchealthadvisor/ParetoLogic%20PC%20Health%20Advisor.exe
follow the link and download the files and scan your computer.
just leave comment
thanks
Mar 10, 2011 | Computers & Internet
I have the canon pixma 160 Inkjet printer.....when tryng to print, it gives me the error message 5010 ...i just refilled my cartridge...also i tried removing the usb wire and switched it off and then...
This error is caused after pulling the printer to bits to fix a blockage. You can fix it by inserting the ribbon cables from the scanner into the circut board properly.
Good Luck!
Aug 27, 2010 | Canon PIXMA MP160 All-In-One Printer
E42 Error
E 42 mean scanner error please service it by a technician
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Service error 5010
that is a scanner error code , prob not worth fixing cost you more to have it fixed than the printer is worth
May 20, 2009 | Canon Office Equipment & Supplies
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Aug 13, 2008 | Canon PIXMA MP160 All-In-One Printer
To get ride of Canon Pixma MP160 Service error 5010.........!!!
Pliz help me out and fix the service error 5010 which i get as soon as i turn on my printer and due to which the alarm light starts blinking, i'm helpless coz either my printer or Scanner isn't working, so pliz stretch out your helping hand in order to let me get ride of this.
Regards,
PRINTER DOT COM
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
180 people viewed this question
old marine
old marine
