Question about Lenovo Computers & Internet
Automatically shutdown, overheating, not charging
My lenovo ideapad N586 7540 will not hold a charge, is overheating and then shutting down frequently. What can I do to fix this?
  • 370 Answers
Not holding a charge is either a bad battery or a bad charger.
Overheating and shutting down is quite common.
1. Overheating can be caused by the cooling air passageway being clogged resulting in little or no air movement.
2. It can also be caused by a bad fan on the heat sink.
Both are easy fixes.
#1. Clean the airway with a can of air.
#2. Disassemble the laptop and replace the cooling fan.
Posted on Apr 23, 2014
billspeer
  • 180 Answers
SOURCE: override laptop automatic shutdown after inactivity
Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
Please rate this solution accordingly. Thanks for using Fixya.com.
Posted on Jan 10, 2009
  • 38 Answers
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
Posted on Oct 28, 2009
silntkill
  • 13 Answers
SOURCE: IdeaPad Y530-5243U 15.4" Laptop PC Notebook: My Lenovo ideapad Y530 fails to turn on with batte...
the battery of your ideapad is already defective, try to change battery
Posted on Jun 12, 2010
shahidkap97
  • 392 Answers
SOURCE: WHATS HAPPEN MY TOSHIBA SATELLITE A300-14S LAPTOP BATTERY NOT CHARGING THEN WHEN I REMOVE BATTERY PLUG DIRECT DC IF HOT AUTOMATIC SHUT DOWN
the laptop cannot ventilate the hot air out.may be a lot of dust covered the cpu fan.go to any service centre and get it cleaned.if you can do it yourself then its fine.it is becoming too hot and is shutting down.
Posted on Apr 05, 2012
SOURCE: Lenovo g550 turns off when power supply is disconnected ,battery shows fully charged
Replace the battery, it's faulty.
Batteries only have a useful life, then they have to be replaced. Sounds like yours is doing like the ink cartridges, where they register as being full of ink when actually there is no ink in the cartridge.
Posted on May 19, 2012
Testimonial: "Yes. Replaced battery and it works fine. Thanks"
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
My Lenovo ideapad z370 keeps shutting down and booting up for no reason?
dude .,, its due to overheating caused by busted heat sink... maybe you should replace it to fix this thing...
Jan 02, 2013 | Lenovo Computers & Internet
My netbook wont turn on
  • check wether there is any battery problem...
  • Or else if netbook shows booting screen before shutting down. try safe mode log in... (mostly keep pressing "F8" key, it will show menu..)
Oct 18, 2012 | Lenovo IdeaPad S10-1208Uw Netbook
I have lenovo z560 (ideapad).it got off automatically,,,
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 05, 2012 | Lenovo IdeaPad Z560(0914-3NU) NoteBook...
Lenovo z560 getting overheated and switched off
if you keep the mains charger plugged in all the time then this can cause the battery to heat up. if you use the laptop in the same position all the time then try removing the battery for use or when the battery is fully charged then remove the charger, this will also preserve the lifespan and battery operation.hope this is of help to you,
Apr 05, 2012 | Lenovo IdeaPad Z560 Notebook
My lenovo ideapad z560(core3i,2gb ram) keeps shutting down automatically.... havent been able to identify any specific reasons for it.. sometimes its stuts down just after bootin...or jst in d middle of...
I suggest try to check these things on your machine.
->Check if the machine is Overheating.
->Check which part of the machine is Overheating.
->See if the Fan of the machine is Running(Feel if the air vent of the machine)
Cause of Automatic Shutdown:
-Memory
-Hard Drive
-Fan is not working
Most likely those are the cause of the machine keeps on shutting down unexpectedly.
Apr 12, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
My battery drains easily, at full charge it will only takes 15mins then it shutdowns
Hi! Surely is a battery problem. THe battery is faulty which can't hold charge on long time usage. Have the battery replaced and you'll be good. HOpe this helps and thank you for using FixYa!
Aug 31, 2010 | Lenovo IdeaPad Y450 Notebook
My battery in my Y510 Ideapad shows full charge but when I go to unplug my power cord the computer shuts down as if there is no battery in it. Is there any way to diagnose this problem? I always keep it...
you should let the battery drain occasionly.it keeps them longer.id say you have wore out the battery by constantly charging it.only other could be adapter is bad.
Sep 27, 2009 | Lenovo IdeaPad Y510 Notebook
Laptop not goes shutdown
get a program called tweakui and tell it to shut down you computer faster.
Apr 21, 2009 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
