Question about Vehicle Parts & Accessories
Honda odyssey front control module location? - Vehicle Parts & Accessories
    Sergeant:
  • 287 Answers
Please explain what you are looking for. Are you asking about the ECM?
Posted on Apr 27, 2014
Location of alarm security system
i would go to the honda dealer they can tell u were it is on the car, and give you a diagram of were it is or google its location on that van and see
Feb 12, 2013 | 2006 Honda Odyssey
Where is the fuse for a 2005 honda odyssey rear wiper
First, please review this article: Where's The Fuse?
Then to answer the question you asked:
There are actually 3 fuses involved in your rear wiper system.
They are all located in the driver's fuse/relay box located under the left side of the dash.
Fuse #7, 7.5 Amp
Fuse #21, 7.5 Amp
Fuse #30, 20 Amp
These same three fuses, if blown, will also have the symptom of the front wipers not working. So if the front wipers are working, the problem has nothing to do with a blown fuse.
There are also several control units involved in making the rear wipers work:
There is the Combination Switch Control unit, the MICU Rear Junction Box Control Unit, and the Relay Control Module. These are also powered (protected) by the fuses listed above.
I would recommend Obtaining a scanner and scanning the Controller Area Network (CAN) in your vehicle to see if there are any fault codes that can help you determine why your rear wipers are not working.
Feb 27, 2011 | 2005 Honda Odyssey
The driver's door lock on my 2004 Honda Odyssey does not respond to the key fob or door lock switch anymore. All other lock actuators and switches work properly. I thought it was the actuator in just...
Has Honda had a look at it? Beside the engine control module
I believe there is a body control module with relays, etc for
functions like door locks, windows, wipers, so it can get
complicated. Best bet is let Honda deal with it.
Jan 30, 2011 | 2004 Honda Odyssey
I'm getting little to no AM and FM reception on my 2006 Honda Odyssey. No one seems to know how to fix this problem.
check the Antenna control module, maybe loose or bad connection. antenna control module located on the right rear side trim panel. Remove the panel you will (ACM).
Apr 22, 2010 | 2006 Honda Odyssey
Where is the speed sensor control located in the 1997 Honda Odyssey.
Lower right front of engine is the main-shaft speed sensor.The counter-shaft speed sensor is located in the lower right rear of the engine mounted in the transmission.
Feb 07, 2010 | 1997 Honda Odyssey
2000 Odyssey A/C in back but not in front.
My name is Ron,I will try and help,You will have a temp door actuator motor that has gone bad,You will have to locate it by process of elimination.Any questions ...roniecon@gmail.com
Jul 19, 2009 | 2002 Honda Odyssey
My 1995 hinda odyssey will not start
check for propper spark, air flow and most important fuel pressure
Jun 04, 2009 | 1995 Honda Odyssey
1998 honda odyssey drl module replacement, where is the module located?
Its up under the dash, like forward of the drivers left knee. 13 wires but the connector has 14 cavities. Roughly the size of a pack of cigarettes.
Apr 16, 2009 | 1998 Honda Odyssey
Front center vents in 2003 odyssey dont work
you may need to change your A/C cabin filter located behind the glove box!
Jan 04, 2009 | 2003 Honda Odyssey
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
