Question about Powerline Computers & Internet
Corinex av200 powerline ethernet adapter password lost
damonumber5
  • 340 Answers
SOURCE: i have 2 comtrend dh-10pf
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Posted on Mar 09, 2009
SOURCE: none of the lights turn
The problem may be occuring because there is no power being directly supplied to the adaptor via the port. If you look on the underside of the adaptor, there is a small button; simply hold this down and slide the 3 pronged plug down to reveal the power port. Clean it of any dust or material which may block it. Firmly place the plug back on the adaptor and check if it works. If the problem still persists, you could remove the plug and use a power cable with a matching port, i.e. a playstation power cable to my knowledge will match it.
Posted on Jun 21, 2009
  • 193 Answers
SOURCE: Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
Posted on Aug 14, 2009
SOURCE: connecting powerline ethernet adapters through orange livebox
  1. Make sure the LiveBox is set to "TV ethernet non active"
  2. Set OFF other existing connections (such as wifi), if any.
M. Razaire
Posted on Aug 20, 2009
  • 88 Answers
SOURCE: Can you explain to an idiot, which exactly what is
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Posted on Apr 03, 2010
The Powerline port does not receive data power, led off
You probably have a fault in either the wiring of the house, the device itself, or one side of the adapter pair isn't functioning.
Jul 28, 2012 | TP-LINK TLPA21 200Mbps AV200 Mini...
Tip
How to Repair a dead TP Link TLPA21 200Mbps Mini Powerline ethernet
TP Link TL PA-211 Powerline Ethernet Adapter tutorial
on Apr 25, 2014 | TP-LINK TLPA21 200Mbps AV200 Mini...
Ikffhhkghj driver
To get the drivers you should always go to the manufacturers website (put the word support in front, i.e - if its hp search google for "support.hp") and you should then find your model number and get the drivers from there.
DO NOT TRUST any program that purports to find your drivers for you or locate missing drivers, always get your drivers from the manufacturers site.
Also, NEVER ever pay for drivers, the manufacturers ALWAYS provide drivers for their products and will never ever charge for the drivers.
Please please remember to vote if my solution was helpful to you, and if I did not help then please let me know and I can try further steps to assist you :)
Nov 01, 2010 | Corinex AV200 Powerline Ethernet Wall...
My router won't link up to my modem. I have a
make sure that you ethernet adapter is enabled. you should be seeing a two computer icon in the notification area. reinstall driver of your eternet adapter.
Apr 01, 2010 | Powerline Ethernet Network Adapter
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Mar 09, 2010 | Powerline Ethernet Network Adapter
Powerline ehernet adapter stuck in standby
1. plug out from the electricity socket and plug it in back
2. check with the electric phase because powerline adapter works only with a single phase in the house
3. a house will have different phase try connecting it in the same phase of the router.
4. or else try updating the firmware from the website for ur particular powerline adapter
Feb 08, 2010 | Powerline Ethernet Network Adapter
Aug 14, 2009 | Powerline Computers & Internet
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Computers & Internet Logo
69 people viewed this question
Top Powerline Computers & Internet Experts
David Payne
David Payne
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
